07-01-2020, 08:34 PM
#1101
Originally Posted by Native
Let's hope the stinging nettles do not grow back through the gravel before you are done with the build.
I suspect they'll be back. The massive ant hill that was underneath the piece of plywood I'd laid down behind my bus has already poked back through. A few days ago I actually spotted a line of ants up the side of my bus (to something dead on the roof, I suspect); they had gone up one of the stinging nettles which was leaning against the side.
07-02-2020, 09:40 AM
#1102
Yellow behind
07-02-2020, 12:58 PM
#1103
Sometimes, I do find it good to move on for a while on the tedious jobs like the underside of the bus. Mind you, I've not begun on our bus underside!
07-03-2020, 11:32 AM
#1104
07-03-2020, 04:00 PM
#1105
I sure hate to see all that purdy yellow go--but I guess that's progress!
07-03-2020, 04:46 PM
#1106
Cutout for accessing fuel tank sender.
I needed to shave the underside of the board to fit over the bits of angle steel around the edges (which are 3/16" thick). My orbital sander did the trick well enough.
Notched so the piece can fit over this bolt head when setting down.
Welcome to Rusty 87! Please make sure you've had your tetanus shots.
The piece was easier to place than I thought. Crawled all over it pressing it down onto the screws and bolts.
I thought it might be kind of difficult to see where the puncture marks were, but they were plain as day.
Drilled out all the holes and routed out the impressions left by the bolt heads. The biggest time consumer here is that I have to take a screwdriver and push the little plug of foam board out of the hole bit each time. Without that problem these holes wouldn't take 30 seconds to drill.
Piece sat back down perfectly.
Most of the way done and then my custom tool started to die. Mark II coming up tomorrow.
Still have to do nine dowels over the fuel tank bolts and five over the rear reinforcement bolts. I think that makes 43 dowels total for this one piece. I spaced these things way too close together, could have saved myself a lot of work.
07-05-2020, 03:14 PM
#1107
Dowel nut Mark II
07-06-2020, 06:17 AM
#1108
07-06-2020, 07:30 AM
#1109
Chassis: Collins
Engine: 6.6L LMM Duramax
I'm on Craigslist alot, but you sure seem to score some great deals on there!!!! Way better than me! Lol
07-06-2020, 08:19 AM
#1110
Ugh, not this time. The thing was in terrible shape, missing parts, and just enormous. Had to just leave it there.
07-06-2020, 08:32 AM
#1111
Chassis: Collins
You win some you lose some... Better luck next time!!
07-06-2020, 04:30 PM
#1112
07-06-2020, 05:53 PM
#1113
It is so refreshing to see someone dedicated to their design philosophy.
I am glad Mark II works better.
07-06-2020, 06:55 PM
#1114
Thanks! But, heh, I might be slightly less dedicated to this design philosophy after running 80 of these dowels over the last two days. I am definitely going to use fewer of these for the front floor section.
Mark II is already dying. I think the issue is that those nails I used are just too soft and bend too easily, even just those little tips. It might last me for the rest of the floor, fingers crossed. Mark III will use thicker nails and shorter points, I think.
07-06-2020, 11:57 PM
#1115
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
ever since you started painting...when I see your posts I an reminded of an article that I read, probably 40 years ago about a gut who would come home every day and paint a small wooden cube with latex paint to relieve stress. After a few years the cube wasn't so little any more but he kept painting because he felt less stressed afterwards.
So.. is the bus making stress or relieving stress?
07-07-2020, 04:19 AM
#1116
Well, the bus relieves stress by making more stress.
07-07-2020, 07:05 AM
#1117
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
So it's a stress transfer device?
STD for short.
07-07-2020, 07:36 AM
#1118
STD for short.
I prefer VD, for "vain disaster".
07-07-2020, 09:31 AM
#1119
Yikes. I just spend 5 minutes fiddling around with my old circular saw to change the blade, and then noticed it was still plugged in.
07-07-2020, 01:43 PM
#1120
Total yikes!
