10-02-2019, 07:38 PM
#101
Test-fitting new seat
Had the bus home so I decided to see how my double seat from a ford transit van was going to fit. I'm going to have a bulkhead wall flush with the back of this, so it needs to be as far forward as possible.
What doesn't work so well is my plan to hang my bicycles on the side opposite the seat. It fits but the handlebars and seat stick out into the aisle too far. I may have to make them both quick-release, or else keep my bikes somewhere else.
10-03-2019, 10:58 AM
#102
Engine: DT466E/MT643
Rated Cap: 77 pax/30k GVWR
I like the passenger seat location. Close enough to have a conversation over the noise of the engine or enjoy the heat on a cold day.
Are you planning on doing one of those hinged stairwell covers? It might make the pax seat a little more comfortable for long trips since your legs wouldn't have to dangle in the stairwell.
10-03-2019, 11:23 AM
#103
It'll probably be removable rather than hinged, but yeah. Also with something like a raised footrest on the forward side of the footwell. Also maybe a sort of desk or airplane-style table in front of the seats.
I was surprised that the seats are actually fairly comfortable, although with two people it would be brutally crammed. The whole thing is only 31" wide.
10-04-2019, 01:33 AM
#104
31" ... not much at all. I suppose two children might fit.
10-09-2019, 05:48 PM
#105
Wiring diagrams from fuse panel door
10-09-2019, 05:53 PM
#106
New identification lamps (rear)
10-09-2019, 05:58 PM
#107
Leveling up
10-10-2019, 03:24 AM
#108
Yeah, handles are a must. You don't want to have to haul them around without handles. I like the ID lights, they look origin.al to me.
10-10-2019, 04:24 PM
#109
Taking the plunge!
And hopefully not the plunger. Found a guy who does welding and fabrication and I'm going to have him rebuild the section of the floor around the wheel wells (or do the big parts, at least). Going to drive the bus to his house tomorrow and the whole job may be done by Saturday.
He's on board with my plan to make a sunken floor. We're going to cut away the existing floor entirely (about an 8-foot long section), then run transverse (side-to-side) beams at the start and end of this section resting on the chassis rails like the original floor, then run two longitudinal (front-to-back) beams attached to the underside of the transverse beams, such that the tops of the longitudinal beams will be flush with the tops of the chassis rails. He'll then add shorter transverse beams that run to the outside walls, as well as a lip on the outside walls that is down 3" from the original floor.
On my own, then, I will build the wooden floor sections (2" joists with foam board in between and 3/4" plywood on top) with painted sheet steel (or some other waterproof material) attached to the bottom (not sure how yet), and lay them onto this new framing (not sure how it will be attached yet). This will give me a fully-insulated floor section that is flush with the original metal floor (giving me an extra 3" of headroom in this section, which will be my kitchen, bathroom and dressing area).
He's also going to build the frame for a sunken shower stall which will go right behind the passenger side wheel well and project 8-10" inches below the original floor. This will give me additional headroom for the shower.
I imagine it will be somewhat shocking to see an 8'x8' hole over my wheels, but the bus is not too far from that as it is.
10-11-2019, 05:10 AM
#110
I do like your sunken floor design!
10-11-2019, 07:19 AM
#111
Year: 98
I like the sunken floor design. Used to live in a bus that had a 6" lower bowling alley in the center ile.
At some moment I would like to do similar in our small school bus.
Not sure if I understand your design.. Where do you attach the remaining stubs of transverse beams that come from the wall? You are not worried about the loss of strength by cutting the original transverse beams?
In my design I will fabricate z shape adapters. The top of the z fit in the standing c shape channel that makes up the transverse floor beam.
The standing part of the z drops the floor down in between the chassis rails and the lower part of the z slides into the short section of the dropped transverse beam.
Maybe a picture of the sketch will help.
Why not insulate in between the transverse beams under the floor?
Good luck
Johannes
10-11-2019, 07:42 AM
#112
Good luck
Johannes
I'm not sure I understand your z-shape adapters, I'd love to see a pic or sketch of it. I'll post pics today or tomorrow of my sunken floor - this will be the first thing on the bus that I didn't do entirely by myself, so I'll be able to take more pictures and videos of the process than I normally can.
I am worried about the loss of strength from cutting out the floor (which incorporates the original transverse beams), but: the sections of wall over the wheel wells are already reinforced with stiffening panels that (I think) are there to compensate for the loss of wall strength that results from the cut-out in the chair rail for the wheel opening. The transverse beams (at the start and end of the new section) are 3" 3/16" angle iron so they'll be stronger than the original beams (which have a web formed from the two C-channels bent into the edges of the panel so it's effectively 2/16"). I had actually intended to use 3" 1/4" I-beams for this but my fabricator convinced me that would be unnecessary here.
Additionally, I'm going to build additional metal support inside the wooden floor panels that I'll be creating, so when attached they will carry some of the load right at the edges of the wheel well openings that was borne by the original floor there (the metal inside the panel will be thermally isolated from the rest of the floor, which is why I'm not just adding a beam here to the new steel framework.
10-11-2019, 07:43 AM
#113
Thanks, we'll see how well it goes today. If it fails completely, I'll switch to Plan B: skoolie hot tub.
10-11-2019, 10:14 AM
#114
Wheel well condition
10-11-2019, 10:35 AM
#115
Deleted fisheye corner mirrors
Anybody know where I can find replacement bits for the plastic around the lights here (the orange bit over the turn signal and the light gray bit around the headlight)? I have new headlights in the mail but I can't find these parts anywhere.
I mangled the bases and the support arms with my angle grinder in the process of removing them, but if anybody wants these for the mirror part (they have cables for heating) you're welcome to them. @CMORGANSKOOL and @HazMatt, you guys mentioned needed one in the thread on this.
I was finding I wasn't really use them when driving, and I kind of like the more open view from the cab now. Removing them also confirmed to me that they are indeed very ugly.
I think also I see the reason that the newer style of these things has a much wider flange to attach them to the hood. The bases on mine had basically carved out deep grooves in the hood just from the vibration.
10-11-2019, 07:05 PM
#116
Year: 98
This is how my design is played out.
Johan
10-11-2019, 09:44 PM
#117
Johan
I like it ... provides strength while relocating the support.
10-11-2019, 10:48 PM
#118
Floor mostly cut out
Thought my passenger side headlight was full of water because of leaking from the mirror brackets, but I just noticed the BB hole:
The guys getting to work on the demo. This is the first thing on the bus that I haven't done 100% by myself - it is very relaxing watching others work.
Floor mostly gone. They still have to cut the back end a few inches more.
The demo revealed a majorly rusted out section of exhaust. The rest of the exhaust has been replaced but this part they couldn't get to easily so it was left as is. They'll be replacing this section tomorrow morning.
10-11-2019, 10:51 PM
#119
Johan
Ah, I see, you're lowering the floor between your chassis rails. As you can see, I don't think I could do that with my bus - too much stuff in the way there.
10-11-2019, 11:17 PM
#120
Year: 98
Wow, you have a strong stomach for rust repair. Some busses do not have a steel floor at all...only treated plywood. I believe some crown and older gmc pd4104 have wooden floors....mine.. a transit bus has a wooden floor. My bet would be that the sheet metal floor is used as fire protection and not so much for strength reasons. Wonder if you can fill the sections between the floor beams in with wall sections of modular freezer buildings.
On my plans for the small bus...I can not go far in between the frame rails either. So the floor end up at the same level as the top of the frame rails. The floor beam C channels are indeed between the frame rails but do not interfere with the stuff going on there.
I only need to cut and lower three floor beams ..in the back, that is under the bed there is no need to lower the floor.
This will give me 4 to 5" more headroom where I need it.
J
