12-20-2020, 04:05 PM
#1581
I used it for the ceiling in my shower. Haven’t done a stress test yet, but it looks good!!
12-20-2020, 06:09 PM
#1582
Just glued in place? I'm wondering if these screws will be necessary.
12-20-2020, 07:59 PM
#1583
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Stainless Marine Washers?
12-20-2020, 11:02 PM
#1584
Yes. I used welwood contact glue. Then I used a polyurethane caulk.
12-21-2020, 01:04 AM
#1585
I would suggest a Dremmel with an abbrasive tip to make the countersink bevels.
12-21-2020, 05:13 PM
#1586
12-21-2020, 05:33 PM
#1587
I used the plastic sheets from homedepot on my custom boat bed, used epoxy to glue a sandwich with styrofoam. Epoxy worked just fine, I would keep metal (i.e. screws) away from a shower if possible.
12-22-2020, 08:16 AM
#1588
I would add that the thin plastic sheets shrink and grow quite a lot with cold and heat, just like flooring does it needs expansion and contraction points.
I've also suggested using vinyl flooring for a shower surround, it comes in 12ft wide and cut to length, so can wrap a shower in a single piece.
12-22-2020, 04:06 PM
#1589
12-23-2020, 04:50 PM
#1590
12-28-2020, 07:03 PM
#1591
12-29-2020, 04:18 PM
#1592
Is that little white snake the future path of your sink drain?
12-29-2020, 04:20 PM
#1593
12-29-2020, 04:22 PM
#1594
Yeah, I bought this material to see if it would work but it's corrugated on the inside as well as the outside so I'm not going to use it. This is just to make sure I can basically snake something through this path. I'm going to attempt to heat-bend PVC for the real drain.
Everything about this tub just barely fits in this space here.
12-30-2020, 03:37 AM
#1595
Hey Musigenesis, when I bend schedule 40 PVC pipe, I use a bucket of water, a wash rag and a Milwaukee heat gun. As the pipe starts to get pliable, you can gradually make your bend, then use your wet rag in the bucket to seal the bend. When you drag that wet rag over the bend it will freeze your bend solid. Takes just a wee bit of practice, but I’m sure you’ll get he hang of it quickly. Just my 2 cents worth.
12-30-2020, 04:30 AM
#1596
Crap, I only have a DeWalt heat gun.
I will try the wet rag thing. I bought some PVC to practice on before I do the real thing.
12-30-2020, 09:49 AM
#1597
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
After everything you've been through preparing (eh, re-pairing. Or is that de-rusting? Whatever) the foundation of your build, it's gotta feel great to get the the point you are now. Tripped out when I saw your first post date wasn't (relatively) that long ago, all things considered. Amazing progress!
Go away. 'Baitin.
Our Build: Mr. Beefy
12-30-2020, 09:51 AM
#1598
Hahahaha !! I guess the brand name really doesn’t matter. I guess it’s guys talking to guys thing. You know, BS. You sound like me, when I haven’t done something, I like to practice on scraps. Be careful, that $hit is hot to the naked fingers. I enjoy reading your build even at 3 in the morning!!
12-30-2020, 04:08 PM
#1599
12-30-2020, 04:10 PM
#1600
Exactly. I should have named my bus "Scraps", in fact.
