01-08-2021, 10:34 PM
#1641
Originally Posted by Native
They sure do change the look of the windows. Interesting.
I kind of like how they look now with the open centers, but alas they will eventually be filled in with XPS foam and then a flat piece of trim will go over the front and they'll just look like ordinary pillars.
01-09-2021, 07:19 AM
#1642
Coachwork: Gillig
Chassis: Phantom
Engine: ISM 10.8L, B400R
The progress is looking good to me, keep marching, its paying off!
01-09-2021, 11:11 AM
#1643
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Is there a purpose for these posts other than looks and some insulation value? They do make it look more solid, substantial and elegant.
01-09-2021, 11:46 AM
#1644
They provide framing for the XPS inserts I'm going to make for each window. I did consider not adding posts and instead having each insert touch its neighbors, but there'd be nothing holding them in at the middle that way. I also considered putting these posts on every other rib and making each insert cover two windows, but I wanted the complete flexibility that one insert for each window will provide me.
The advantage of attaching them with the original window screws like this is that I can easily remove them if I need to replace a window (which I already do, having broken three of them so far).
01-09-2021, 02:15 PM
#1645
Rated Cap: me + 1
Sounds like a good plan. Are you going to cover the XPS inserts with fabric, paint, or ???
01-09-2021, 02:22 PM
#1646
Rated Cap: me + 1
PS. Lazy as I am, I would have probably have figured out a way to use magnets to hold the inserts in and would never have considered the looks that the posts achieve.
01-09-2021, 02:51 PM
#1647
They'll be faced with 5mm plywood, same paneling as I'm using everywhere else. I've already made two of them but I can't find it in my own build thread. The ones for the side windows will be hinged so they store more compactly. I'm going to build an underbody storage bin to keep these in when they're not in use.
Edit: here it is.
01-09-2021, 02:52 PM
#1648
Hmm, magnets would have been an interesting idea.
01-09-2021, 03:02 PM
#1649
One other benefit of these posts is that there will be a few places where I have to run wires from below the windows to above them, and I can channel them behind these posts pretty easily. Also they're going to hold the screens for the windows.
01-09-2021, 05:54 PM
#1650
Finally occurred to me to raise the miter saw up to my level. Also hooked up an old Bose radio for some music - this is the first time in two years I've ever worked with music playing, it's quite nice.
More window posts.
Measure twice cut once.
Measure thrice cut twice.
Finished the passenger side posts, except I need to trim the fronts of all of these.
01-11-2021, 07:04 PM
#1651
01-12-2021, 12:23 AM
#1652
I love the progress Musigenesis. You should be proud. I know the rest of us are !!
01-12-2021, 02:59 AM
#1653
+1 ... looking great!
01-12-2021, 06:43 AM
#1654
Thanks guys, I am pretty proud. Of everything but the fact that my two-year skoolieversary is a week away!
01-12-2021, 07:28 AM
#1655
Chassis: Collins
Engine: 6.6L LMM Duramax
It'll all be worth it when you are done and enjoying it and won't have to worry about it!
01-12-2021, 04:31 PM
#1656
01-13-2021, 12:32 PM
#1657
01-13-2021, 03:35 PM
#1658
The bench seat pulls arrived for my toilet. They're a bit smaller than I thought they would be (the listing was accurate, my brain was not) but I think I'll still use them.
I might mount them side by side like this.
My dowel tool is nearing retirement. Only 5 or 6 more to do.
This is a different variety of 5mm underlayment panel, from Home Depot. I like it more than the other kind from Lowe's which has some cracking and peeling on the top layer (I can fix it but I'd rather not).
01-13-2021, 04:56 PM
#1659
Making some real headway !!! Love the progress.
01-13-2021, 09:10 PM
#1660
Thanks! Two years of work and I'm so, so close ... to a featureless white room. It will be a self-propelled white room, at least.
