05-24-2021, 10:33 PM
#1921
Well you’re definitely heading in the right direction. You haven’t lost your sense of humor. Keep up the GREAT work !!
05-25-2021, 09:37 AM
#1922
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Hey MG, this is looking great. I'm a couple of weeks behind and just picked up again where you found a $10 stair tread. Finding any $10 board now seems like a huge bargain. I'll have to scope out that section of my Home Depot.
05-25-2021, 12:03 PM
#1923
Thanks! I'm really liking working with the stair tread - I'm completely not used to using wood that is perfectly straight and stays that way after ripping on the table saw.
Keep it on the down low, please, I don't want to start a run on this stuff.
05-25-2021, 07:35 PM
#1924
Installed the back part of the shelf.
Definitely some sagging without these vertical supports toenailed into the furring strips.
Splicing together the front part of the shelf. Definitely a PITA but better than the $130+ the badly warped poplar 1X was going to cost me.
Not too bad for $50 worth of step tread.
05-25-2021, 07:36 PM
#1925
Originally Posted by Bert06840
Awesome, just joined this thread. Can’t wait to see more.
Welcome, glad to have you aboard.
05-26-2021, 04:36 PM
#1926
Splinted the top trim piece for my rear storage bin.
Clamp and straight edge helped me keep it lined up straight on the ceiling. Ran some 3" screws into the ceiling; they won't provide any weight support since they're just into 5mm plywood, but they'll keep the piece from shifting in or out.
Filled the big counterbores with dowel.
For anybody starting out, I really recommend these vibration-dampening gloves: https://www.amazon.com/gp/product/B00BHMLJ2S/. My arthritis pain is so much worse without these.
My mom found this today in my grandfather's stuff. He worked for Thomas Edison as a machinist in the '10s and '20s (the last batch of '10s and '20s) before quitting and opening his own shop. This is a gadget that he invented (late '40s/early '50s) and was going to sell before another invention came along and made his obsolete. I missed out on being born into obscene wealth, I suppose, although my mom would probably never have married my dad if she had come from money.
Gadget with the handle closed. I thought it might be fun to post this and see if you guys can guess what its purpose was.
Had to cut the corner piece of paneling here so that the overhead storage won't prevent me from ever removing it (it has to be removable so the side pillar can come out and allow the window to be removed and replaced).
This bin over the desk is less deep (20" as compared to 26" for the back bins) because I don't want to it be too obtrusive and I don't want to smash my face into it every day.
05-26-2021, 05:44 PM
#1927
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
"Gadget with the handle closed. I thought it might be fun to post this and see if you guys can guess what its purpose was."
Anyone remember "The Liar's Club" TV show? An item would be presented to a group of celebrities and each would explain what the item was, but only one told the true story.
This is a perfect item!
Given Musigenesis' wide use of dowels, this was obviously used to size dowels and make sure they were strong enough to hold up tables
05-26-2021, 05:49 PM
#1928
Ha ha, good guess. But wrong!
Thanks for the Liars' Club link - that should keep me busy for a few weeks.
05-26-2021, 06:17 PM
#1929
Year: 98
Castration tool.
Have fun
Johan
05-26-2021, 06:42 PM
#1930
Chassis: Collins
Engine: 6.6L LMM Duramax
I would say banding tool for bull calves. Like Johan mentioned- a Castration tool. We use pliers with same concept to put a stiff green "rubber band" on. Also, a sharp knife works well but is a little messier...
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
05-26-2021, 08:17 PM
#1931
Heh heh, not a castration tool - maybe if the ratchets worked the opposite way (i.e. if the center teeth closed when the handle closed instead of opening). Ouch.
In a sense, the tool's purpose is the opposite of castration.
05-26-2021, 08:31 PM
#1932
Chassis: Collins
Here is what I'm talking about...
We'll see if the screen shot shows up correctly!
05-26-2021, 08:58 PM
#1933
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
[QUOTE=musigenesis;439903]
/QUOTE]
Used when filling balloons with helium?
05-26-2021, 09:39 PM
#1934
Yeah, that action (the stretching out of the band so it can be placed around the testicles) is very similar to what grandad's device did.
The gadget was used for placing sterilized rubber nipples onto baby bottles. You'd use the pincers to pull the nipple out of the boiling water and onto a clean towel, then the ratchet/toothed part to spread it out and place it over the neck of a glass bottle, all without ever touching it.
He called it the Nipple-On, which is why I like to style myself as "the heir to the Nipple-On fortune". He was defeated by the appearance of disposable plastic baby bottles.
05-26-2021, 09:45 PM
#1935
Chassis: Collins
That is really amazing idea he came up with for installing the nipples on the bottles without ever touching them. Really cool piece of history and innovation you have with a good story to back it. Fortune or not, you should be proud of that!! Thanks for sharing
05-26-2021, 09:58 PM
#1936
Thanks, happy to share it.
05-27-2021, 04:22 PM
#1937
Rated Cap: me + 1
Could make a comeback. Pantyhose pretty much put stockings and garters out of business, but they are having a resurgence. Could even be marketed as a sex toy to the SM crowd LOL
05-27-2021, 04:26 PM
#1938
Ha ha, the gadgets actual have "patent pend" stamped on them and my mom thinks she remembers her father submitting a patent application for it. If I get some time I might research it - I could maybe still get my money by being a patent troll.
05-27-2021, 06:54 PM
#1939
05-28-2021, 08:55 AM
#1940
Chassis: E350 7 window
Engine: 7.3 idi na
Rated Cap: 16
The attention and documentation of the details is blowing me away! Going to be stealing your upholstery process!
