Old 06-03-2021, 01:47 PM   #1961
Originally Posted by Oscar1 View Post
I'd like to thank all you blockheads for confirming my wife was right when she demanded no overheads. I wanted and she didn't and if she see's this thread I'll never hear the end of it.
Cheers
Your wife was absolutely right. In fact itzz flhie aasef ehe ssl dkjfe.
Old 06-03-2021, 01:48 PM   #1962
Rats, page 99 already. I had this fantasy going of finishing the thing on page 100.
Old 06-03-2021, 08:46 PM   #1963
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Cheers
Is your wife tall? Buy her a padded hat.
Old 06-03-2021, 08:52 PM   #1964
Engine: C7 Cat
Haha! She's only 5'4". I think she was looking out for my safety, that or maybe she was trying to avoid all the blue language
Oscar1 is offline   Reply With Quote
Old 06-09-2021, 07:36 PM   #1965
Spent the last week tending to my parents in the hospital (fortunately serially rather than in parallel) but I was able to get back to the framing for my vent hood and microwave oven today.
These things are getting a lot easier to build, since I can use the existing bin framing as templates.
Old 06-09-2021, 10:36 PM   #1966
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Sorry about your parents illness. The progress on the bus is great!
Ted
Old 06-10-2021, 12:22 AM   #1967
Rated Cap: me + 1
Attachment 58298
Attachment 58299
Attachment 58300
Hope your parents are ok.
Old 06-10-2021, 05:11 AM   #1968
Parents are OK! Thanks for your concern.
Old 06-10-2021, 06:10 PM   #1969
Finished the framing of the shelf for my microwave.
This should fit almost any 0.7 cu ft microwave if I ever need to replace it. I searched and there's one variety that is 19.2" wide and it won't fit, but everything else will.
Some extra supporting blocks for screwing the vent hood into.
Went in OK. I'm a bit unsure if it's supposed to be sticking out this far, but it's basically centered over the range.
Built a removable section to cover the area behind the hood.
I have an external damper ready to install once I get a few rain-free days. I'll have to cut an opening above the window for it and fabricate a piece to create a flat area for it. People with flat-sided RVs have it so easy.
The damper only sticks inside 1.75" so I'm going to have to fabricate a very long bit of ducting to reach from it to the back of the hood. I'm not sure what effect that will have on the draw - probably not good, but hopefully it will still be strong enough to do the job.
The "REMOVE" is to remind myself of which screws need to come out to remove this back piece. It will need to come off when I do the damper and the ducting.
Old 06-11-2021, 12:56 PM   #1970
Rated Cap: me + 1
Attachment 58333
Attachment 58334
Attachment 58335
Attachment 58336
Attachment 58337
Attachment 58338
Attachment 58339
Attachment 58340
Attachment 58341
Attachment 58342
Attachment 58343
Attachment 58344
Microwaves exhaust heat and steam (not good for wood). Some can handle being in an enclosure, some not. Sharp used to make a microwave that was also an electric oven and you could put metal in it. It even came with a metal grill for a turntable. Great space saver for someone like me that does not cook often and doesn't cook Thanksgiving dinners. It was also a time saver and you didn't have to have so many microwave only dishes/utensils which also saved space.
"Remove" - common practice in some industries is just to draw circles around the screw/bolts that need to be removed for shipping/re-uninstall etc. Notes are okay, but some take it a step further and include printed pictures, especially for repacking.
Old 06-11-2021, 01:28 PM   #1971
I'm going to add some vents/holes to the box holding this microwave. I'm also probably never going to use the thing, which will help keep temps down.
These won't need to be removed permanently, they're just to remind myself of how to remove the back piece so I can get at the exhaust duct. It's amazing how quickly I forget how I built something - one of the big benefits to a build thread.
Old 06-11-2021, 06:58 PM   #1972
Yay auto-focus. This sort of shows blocks screwed into place to keep the microwave from sliding around.
I guess this will keep it from bouncing out while driving, we'll see. Hopefully I won't find out via a loud crashing noise. I may have to add something at the top to keep it from bouncing up.
My replacement hood arrived today and I should be able to swap it out tomorrow. Shout-out to etrailer.com for a reasonable return policy.
Old 06-11-2021, 09:02 PM   #1973
Engine: C7 Cat
Awesome looking work on the microwave and range hood
Top notch!
Cheers
Old 06-12-2021, 07:03 PM   #1974
My technique for fitting panels to the curved ceiling: first I rough-cut it to within 1/4" or so by taking height measurements every 3", then I tack it in place 1/2" lower than its final position.
Then I set a pencil compass to 1/2" radius and scribe a line on the piece 1/2" down from the ceiling, holding the compass perfectly vertical.
Then I cut outside the line with my bandsaw and sand the line off with my orbital sander. The piece then usually pops right into place, sometimes with a little extra sanding of the edges to get it to fit.
Typical skoolie action: I finally get the hang of a task just as I'm finished with it forever.
Old 06-12-2021, 08:32 PM   #1975
Man, I am the biggest menace to my bus windows. Just broke my fourth, this time repositioning my bus in my parking space. I left the passenger doors open to do it and smashed the bottom pane of one of the doors into my chock-block which was leaning up against the fence. Not a huge deal since the door is in rough shape and will have to be replaced with something anyway, but I feel like the gradual accumulation of broken panes of glass is likely to encourage vandalism. Fortunately it's safety glass so it's at least still intact.
build thread
