07-26-2020, 09:13 PM
#1161
Originally Posted by bp1791-unleashed
I just finished the whole thread. This is awe inspiring work. I'm super impressed with it.
I really like the dowel/cube idea for spacing with the insulation. I might borrow that in some variation.
I can't wait to see the rest of the progress.
jim
Thanks very much! For the record, the cheese cubes aren't really part of the system, they're to keep me from stepping on the ends of the welded screws. I'm pretty sure I would have lost a foot by now without them.
07-27-2020, 12:30 AM
#1162
Coming right along!
Good to see all that YELLOW down on the floor.
07-27-2020, 07:40 AM
#1163
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
I've got an ant infestation, actually.
I bet they think it's cheese too. Once your flooring is done they will be gone.
07-27-2020, 11:20 AM
#1164
07-27-2020, 03:11 PM
#1165
Chassis: Ford e450
Engine: 7.3 powerstroke
Rated Cap: 20
Nice work! There's something satisfying about seeing that floor with it's cheese cubes.
07-27-2020, 06:27 PM
#1166
New bracket for bottom bar of side door latch
I'm amazed I still have anything that I pulled off my bus more than a year ago, but unfortunately I lost the bracket that guides the bottom bar on the side door. It wouldn't have worked without modification anyway (since I'm catching the bar on vertical sill piece), so I just built a new one to fit exactly.
Happened to have this piece of bent 1/8" sheet that I ordered from my metal supplier last year for something I ended up not doing. So convenient to have random pieces of metal floating around.
SEM self-etching primer.
Rustoleum semi-gloss enamel.
07-27-2020, 10:28 PM
#1167
I keep all sorts of little bits and pieces of metal just for that sort of thing. Sure, if you have a real good supply of stock and a brake, drill press, vice, etc. you could get away with tossing all the scraps. Not so in my garage!
07-28-2020, 02:43 PM
#1168
07-28-2020, 06:53 PM
#1169
Painted kitchen floor plywood.
07-29-2020, 04:14 PM
#1170
Front subfloor half completed
07-29-2020, 08:54 PM
#1171
How awesome does that look to you? Freaking nuts how different this looks than it did in November.
07-29-2020, 09:50 PM
#1172
It does look pretty awesome. I don't have any rusty disastrous messes inside the bus any more. Also fun to walk on this floor.
My happy is tempered by the fact that I spilled a bit of gasoline in the back of the bus on the drive back to my lot, which ate away a bit of the XPS. I'm probably going to have to remove two of the back pieces of plywood flooring to fix it. The drive over I was smelling the gasoline and thinking "ha ha, that's not me, my bus is diesel!" and forgetting I have gasoline jugs for my generators.
07-30-2020, 12:52 AM
#1173
Wow, that is a bummer! Gasoline + XPS = molten mess!
07-30-2020, 07:10 AM
#1174
So far, I have trashed already-installed XPS by 1) welding near it, 2) spraying weld-spatter onto it, and now 3) pouring gasoline on it. Really wish I could have done the ceilings and walls first.
It looks like the gouge is maybe a foot long and an inch deep, and this was just from a tiny trickle of gas that seeped out of a mostly-empty can. If a full can had spilled, I'm pretty sure I would have had to redo the entire floor back there, including the dropped part.
No more hauling gas around in my bus, unless it's in my step well.
07-30-2020, 08:53 AM
#1175
Rated Cap: 34
On the other hand, you may have discovered an alternative to the routing out of pex lines for radiant floor heating.
07-30-2020, 05:11 PM
#1176
Subfloor complete
Filler piece.
Fitting the big piece.
Unfortunate gaps.
Buckets o' dowel.
Big piece doweled.
The gasoline damage. I'm kind of worried about the bits against the wall since I don't know how far it went down there.
An attempt at a closeup under the lip of the plywood.
Anybody need a bucket of perfectly good 1.5"x1.5" cubes with holes in them?
Insulation complete.
More gap fillage.
Plywood laid.
My hero! Didn't think this tool would last, but it finished out the floor.
Plywood all screwed in place.
This is a big milestone for me.
07-30-2020, 05:15 PM
#1177
Chassis: Saf-T-Liner
Engine: CAT 3126E210
Rated Cap: 33,050 pounds
Looking good! Wow!
Bummer about the gasoline, but I'm really glad it was only a tiny amount, and there was no ignition source around.
07-30-2020, 05:53 PM
#1178
Looking good! Wow!
Thanks!
Life is like a teacher who believes in corporal punishment.
07-30-2020, 07:30 PM
#1179
This is a huge milestone indeed! Your flooring now looks like you never had any rust at all! WooHoo!!!
07-30-2020, 08:35 PM
#1180
Thanks a lot. It's pretty strange to be in my bus now after imagining this for so long.
I have of course already tripped on the edges of the sunken part two or three times. I'm reasonably certain I'm going to step backwards over the edge at some point and turn my ankle. But somehow I managed to never impale myself on one of the upright screws.
