12-16-2020, 07:31 AM
#1561
Originally Posted by Native
Re the tub: At least the piece you are to glue and solder is not a water HOLDING portion of the tub and is a watershed portion instead.
Yeah, that's the only reason I'm even attempting this. If it was something that water was going to sit in, I'm pretty sure it would not work.
One other potentially handy thing about this dropped tub is that if I get a leak, all the damage will be to this lowered part and should (may?) be easier to repair - as opposed to the water going to some other unknown part of the bus.
Re your skills: They are indeed top notch and your speed is incredible. I wonder every day how you can keep up with the thread, let alone the actual construction.
Well thank you. The thread thing is not too difficult, though - I just take a quick pic once in awhile (probably too often) and then post them when I'm taking a break. Biggest hassle is converting them all to PNG.
12-17-2020, 04:37 PM
#1562
First snowfall for my bus!
At least I assume so. I don't think it would have seen any snow in Buffalo.
12-17-2020, 08:46 PM
#1563
Attachment 52057
Nor in Texas:
... but this was NOT from this year.
12-17-2020, 09:17 PM
#1564
Man, snow in Texas! You're lucky your neighbors didn't kill and eat you at the first sign of a snowpocalypse like that.
12-17-2020, 09:38 PM
#1565
Yeah, but perhaps they saw me using my acetylene torch and were afraid!
12-17-2020, 09:47 PM
#1566
I guess they prefer sushi.
#1567
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Your recessed tub is going to be super cool. I might need to try something similar. Is the drain going to gravity feed to your gray water tank or are you pumping it in?
Ted
12-17-2020, 09:49 PM
#1568
BTW Native, I don't know where in Texas you are exactly, but I always imagine skoolie builders in Texas living in China Grove.
12-17-2020, 10:00 PM
#1569
Ted
It's going to be gravity - hopefully, anyway, the arrangement is going to be pretty tight. I have one of those long, flat black tanks (9" high) that I'm going to use as my gray tank, hanging behind and below the tub. The tub drain will do an immediate 90 degree to horizontal coming out the back and then I'll have a hepvo valve and a straight run back to the hole on top of the tank. There should be just enough room to have enough of a downhill slope between the tub bottom and the tank top, and keep the bottom of the tank at about the bottom of the side skirt (I could go a little lower than that if necessary, I think). For extra complication, the drain from the sink (right next to the tub) is going to have to sort of snake around between the tub and the wall and join into the tub drain before exiting the box.
If I could re-do my plan, I might skip the under-the-floor thing for the tub and instead just build a slightly larger projecting box above the roof than the smallish one I built for my Maxxair fan and get the needed head room that way (although I think those boxes do look kind of weird from outside if they're too large). Overall it would have been much easier since I had to build that roof box anyway, and it would have made the gray tank arrangement much simpler and easier.
12-17-2020, 10:19 PM
#1570
Fort Worth , TX .
China Grove ... every time I hear that I think of the song:
12-17-2020, 10:28 PM
#1571
Chassis: CS RE
Sounds like your drain plan should work just fine and it will be worth it to have the extra head room.
Ted
12-17-2020, 10:41 PM
#1572
Fort Worth , TX .
I have a friend who lives in Dallas and I almost bought a house there around 2008, one designed by a semi-famous Dallas architect whose name I forget (he was sort of Frank Lloyd Wright-ish). The house was run down and super-cheap (no takers for years at $50K) but the thing I was most into about it was this very cool tiny house on the property with a full-height upstairs sleeping platform with a huge skylight over it. I was going to renovate that first and then move into it while renovating the main house. I think this was the first glimmer of my skoolie dream - I spent years afterwards fantasizing about what I would have done with the tiny house. This was in the SE part of Dallas which seems under-popular - there are some very cool older neighborhoods there.
When I first got my first Z3, I drove over to visit her, going from Shreveport to Dallas in an hour and fifty minutes, which is a little bit quicker than you're supposed to make it.
12-18-2020, 01:17 AM
#1573
I have a friend who lives in Dallas and I almost bought a house there around 2008, one designed by a semi-famous Dallas architect whose name I forget (he was sort of Frank Lloyd Wright-ish). The house was run down and super-cheap (no takers for years at $50K) but the thing I was most into about it was this very cool tiny house on the property with a full-height upstairs sleeping platform with a huge skylight over it. I was going to renovate that first and then move into it while renovating the main house. I think this was the first glimmer of my skoolie dream - I spent years afterwards fantasizing about what I would hone with the tiny house. This was in the SE part of Dallas which seems under-popular - there are some very cool older neighborhoods there.
That house sounds like a skoolie builder's dream!
Uh, that's averaging just under 100 MPH!!!
12-18-2020, 06:09 AM
#1574
Chassis: IH 3800, 8 window
Then there're thems of us in residence a mite closer to La Grange.
https://youtu.be/Gg9cNGHl-bg
Unh how how how...
12-18-2020, 06:32 AM
#1575
Originally Posted by HazMatt
They gotta lotta nice girls there.
12-18-2020, 06:53 AM
#1576
Git you an hm-hm
12-19-2020, 04:47 PM
#1577
12-19-2020, 11:23 PM
#1578
Lookin' less and less like a bus!
12-20-2020, 02:15 PM
#1579
12-20-2020, 02:17 PM
#1580
True, I'm not sure what it does look like, though.
