01-03-2021, 09:43 AM
#1621
Yup, and you're a lot less likely to end up with food poisoning!
01-03-2021, 10:18 AM
#1622
Interesting, it seems that hard polyurethane is food-safe once it cures completely (30+ days or so), so long as you're not cutting into it. I think I may go this route with all of it, since I never intended to use it as a cutting board.
01-04-2021, 04:15 PM
#1623
01-04-2021, 04:37 PM
#1624
Because you have to design, engineer, and then build. We probably would give engineers nightmares watching some of our builds. You’re making great progress Musigenesis. Keep the faith !!!
01-04-2021, 04:51 PM
#1625
Thanks, man! I like to think that an engineer would at least sleep better after seeing my build than after seeing the guy who tried attaching his roof deck with double-sided adhesive tape.
01-04-2021, 05:46 PM
#1626
Oh damn !!!
01-04-2021, 10:44 PM
#1627
Nice looking teak table. *Almost* a shame to cut it. It will be a wonderful addition to your build.
01-05-2021, 05:57 AM
#1628
Thanks, although the more I look at it up close the less I like it. I thought it was not veneer but it clearly is. Oh well, it will be mostly covered by a desk pad anyway and I'll be able to easily replace it down the road if I feel like it.
01-05-2021, 04:17 PM
#1629
Genius move here - realized I should stop walking 100 ft. to go cut every piece of wood in my shed.
Stiffening the frame. This toilet is pretty overbuilt but I'm sort of practicing for the kitchen cabinets which will be built pretty much the same way.
The lid for this is going to be 1" thick plywood but I still really want it to not sag at all, so this extra bit of frame will support next to the toilet seat.
I was unsure whether I wanted to cut this piece off at an angle, but it was slightly floppy since it's just a corner of plywood and I think this looks a bit better, maybe.
Thickening it up a bit since I think nothing says "plywood" better than a piece of wall that is plywood-thick.
I have been making a huge number of off-by-1/4" errors in my carpentry and I think I noticed why today. I apparently have a tendency to read the 1/8" marks on the wrong side of the inch mark, so 18 1/8" becomes 17 7/8".
This one was easy to pull out and correct, fortunately.
Spent some time fitting this triangular piece perfectly.
And then randomly grabbed it and cut a 2" wide strip off it that I needed elsewhere without realizing I was using my cut piece. I'm normally pretty mellow while working but this got some swear words out of me.
These two pieces are bevel-cut at the corner, so I'll see tomorrow how decent I can make this look. I just want to avoid the tippy-tip-tap with a hammer stuff.
01-06-2021, 12:33 AM
#1630
It looks pretty good in he picture. So maybe it is not such a "crime" to cut it after all.
01-06-2021, 12:35 AM
#1631
Attachment 52682
LOL ... perhaps you were waiting for the fancy platform to be in place first!
01-06-2021, 03:05 PM
#1632
01-07-2021, 04:02 PM
#1633
01-07-2021, 04:18 PM
#1634
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I don't know why hole saws are such torture for me to use, but this especially sucked on the underside.
If you're using the typical toothed hole saw, even the bi-metal ones, they do indeed suck on metal...especially thin metal, because as they break through they tend to grab. Heck, they grab even before they break through...and then want to take you skating across the surface.
I've had much better luck with the carbide tooth saws and I have a set of Greenlee hole saws which you'll find in the electrical section of Home Depot, because they work well punching holes into metal boxes. They aren't cheap, but they're worth it if you drill more than one hole.
Here's a photo of the type I mean, snagged from the DeWalt site:
01-07-2021, 05:34 PM
#1635
Ha, yeah that's my exact experience.
Very cool, I'll check those out.
01-07-2021, 05:36 PM
#1636
I've always had shitty luck with hole saws, too man.
01-07-2021, 05:39 PM
#1637
I'm glad I'm not alone.
01-07-2021, 11:09 PM
#1638
I realized today that it is indeed 53" - but that I actually need something 55". So the crime may be me cutting it up for firewood.
01-08-2021, 04:50 PM
#1639
01-08-2021, 10:20 PM
#1640
They sure do change the look of the windows. Interesting.
