07-24-2022, 04:28 PM
#2361
07-25-2022, 07:25 PM
#2362
07-26-2022, 07:17 PM
#2363
First trim pieces in place.
I'm going to have to pull all this stuff out again to paint it. Sigh.
07-27-2022, 12:18 AM
#2364
Coachwork: Crown by Carpenter
Rated Cap: 16
Man, so exciting to see your bus come together after all the work you put in to get rid of the rust!
Great job!!
07-27-2022, 10:12 PM
#2365
Slow going but I managed to trim my lintel at least. This was just a spacer piece and I can't for the life of me remember why it was necessary.
So happy a past version of me bought a band saw.
This curved top piece should look better once it's painted.
Since the door opens outward, these trim pieces overlap the jamb by about 1/4" to prevent air getting through the gap between door and frame. It will make the opening a tiny bit smaller.
07-27-2022, 10:13 PM
#2366
Great job!!
Thanks very much, I appreciate it. Feels good to be working on this again after a nine month hiatus.
07-28-2022, 06:58 PM
#2367
07-29-2022, 02:26 PM
#2368
Year: 86
Chassis: Ford B700
Engine: 8.2
my collins bus has panel latches that by design act like they are spring loaded but they are not but to open the access panel you just flip the latch open and to close the panel you just flip the latch back over edge of the hatch.
pretty heavy duty and shouldnt be to expensive.
maybe try collins website or busparts.com for collins panel latches?
maybe thats what they are called.
07-29-2022, 02:35 PM
#2369
Year: 86
Chassis: Ford B700
Engine: 8.2
i just tried to do a quick search and didnt find what i am talking about yet but i did find the dang burgaclip/ refrigerant fittings and clamps i looked for far months on end before i changed the entire system instead of just fixing what i was left with from the previous owner.
tesco bus.
07-29-2022, 05:54 PM
#2370
07-29-2022, 05:58 PM
#2371
These are what I have already: https://www.mcmaster.com/draw-latche...-draw-latches/. Maybe they're similar to what you have on your bus?
07-30-2022, 07:53 AM
#2372
Year: 86
Chassis: Ford B700
Engine: 8.2
thats it.
glad you already have it worked out.
07-30-2022, 11:48 PM
#2373
07-31-2022, 06:37 PM
#2374
08-01-2022, 06:33 AM
#2375
Looking great, man.
08-01-2022, 07:56 PM
#2376
Some ceiling panel seam trim. I kind of like the Tudor-style of this trim, even though I'll be painting it white eventually. It's just too cheap and nasty up close to work as bare wood.
Lintel trim for the side door.
Finished the side door trim.
I cracked the oak strike plate I made for this latch, need to redo it tomorrow. I'm also going to have to attach some wood to the door to fill this gap that was needed to allow the latch mechanism to swing past.
08-01-2022, 07:57 PM
#2377
Looking great, man.
Thank you, I appreciate it!
08-02-2022, 07:53 PM
#2378
08-02-2022, 07:54 PM
#2379
I wonder if I'm going to be done with this skoolie before I hit page 200 of this thread?
08-02-2022, 08:07 PM
#2380
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Wait-you've done all this with a manual screwdriver?? Do you use slotted screws too? That's painful to think about.
