Old 07-31-2021, 08:23 PM   #1
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
Shore power with 12 with ground plug
Hello Again,
Is there a shore power connection that has the rv connection on the shore side to a normal two prong plug with ground that I can run to my bus thru the window so I can have temp power until I get the correct set up?
Thanks again all.
Don
Hiyu is offline   Reply With Quote
Old 07-31-2021, 08:47 PM   #2
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Maybe an adapter from a 30A cord cap to a 15A receptacle? (or vice versa)
The GFCI version cost a bit more, but is much more kid & pet safe (no shoes).
Frederick Douglass:
"A man is worked upon by what he works on. He may carve out his circumstances, but his circumstances will carve him out as well."
Old 07-31-2021, 08:58 PM   #3
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
cord
Yes, the one on the right! Do they make that in a twenty foot cord?
Thanks!
Old 07-31-2021, 09:09 PM   #4
DeMac's Avatar
Engine: 466ci
Rated Cap: 90
Sure. Would you like two written estimates? If you have our credit card available, I can place your order now.
(jk)
Frederick Douglass:
Old 07-31-2021, 09:33 PM   #5
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
What is the bottom one with the GFI called and where can I order one?
Thanks so much....
Old 07-31-2021, 09:33 PM   #6
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
I went to my local rv dealer and they didn't have a clue how to adapt a power cord. I wasn't impressed
Old 07-31-2021, 09:40 PM   #7
DeMac's Avatar
Engine: 466ci
Rated Cap: 90
Camping World hires right off the street.
Bottom one is just called GFCI Protected
Keyword search:
30A Male to 15A Female Adapter
(aka: pigtail)
Frederick Douglass:
Old 08-01-2021, 12:04 AM   #8
Be very careful with these over time, especially if you buy on price (don't)
Next time you meet a real electrician (not anyone in the USA RVing biz) ask them to walk you through how to verify everything is OK internally with a DMM.
First signs of visible damage, replace.
Also never assume the power pole was installed correctly, so many are downright lethal.
Old 08-01-2021, 08:27 AM   #9
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
Sound advice, not to worry will do my homework and buy the best,safest gear out there. Name of the game is to enjoy in safety....
Thank you
Old 08-01-2021, 06:06 PM   #10
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Thank you
It should be UL listed. You wouldn't believe the crap I've seen even out of famous name stores.
I once bought a heavy gauge extension cord only to find out that the polarity was reversed within the cord. Always wondered how many were like that. I worked but was not safe and I only discovered it because I was using it to remote an outlet during troubleshooting on a house and using a plug in tester that showed if things were properly wired.
We've done so much, for so long, with so little, that we can now do the impossible, overnight, with nothing.
The United States Marines, America's 911 force -- 6531, 3521 '79-'99
Retired mech (auto/aviation), Extra Class HAM, NAUI/PADI OpenWater
HamSkoolie is offline   Reply With Quote
Old 08-08-2021, 12:57 PM   #11
We use a wishbone adapter. Goes from 30 to 15 AMP with a regular outdoor extension. cord. Please note that we have found that plugging in to the 20AMP GFCI in our garage causes the GFCI to pop and eventually break. We plug in to regular household outlet and we run 100 ft of utility cord out to the bus. Works well. No apparent heating of the utility cord either - which we experienced when plugging into the GFCI in the garage. It draws the 15 AMPS only but is plenty to charge our battery bank.
Winter-Vale is offline   Reply With Quote
