05-05-2019, 11:14 AM
#461
Chassis: AARE
Engine: 3116 Cat 250hp
I got a new toy. I was going to put in the windshield but, the tint is too dark. Now I'm going to have to build some sort of marquee. I've been having a bit of fun designing some pictures to fit. UI for the Chinese program is a bit odd but I have it mostly figured out. Here's a test of some of the pics I designed for it.
05-05-2019, 11:34 AM
#462
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
good stuff
05-09-2019, 02:24 AM
#463
Totally something I want to have on my future bus.
Also either a nice dashcam, or a little window for a GoPro.
05-09-2019, 09:29 AM
#464
Engine: DT466E (195hp, 520tq)
Pretty cool! Can we text images to it??
Dave
10-09-2019, 09:38 AM
#465
Chassis: AARE
Solar/lithium
Been working on my solar/lithium set up. Here's a proposed wiring diagram for my bus. Only thing I'm not really sure about is whether to put circuit breakers between solar panels and charge controller. I already have 4 of the batteries installed and am using them. Two more batteries to be picked up the end of the month. All solar is purchased awaiting install.
Not included in this diagram is the heated pad circuit for keeping the batteries warm and wiring for the latching contactor that will unhook batteries in case of heat fail. Latching contactor also has a switch in cabin to manually unhook batteries for everything. Start battery is included because the inverter/charger has an extra circuit to maintain the start battery.
10-09-2019, 10:58 AM
#466
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Looks like a nice set up! I really like the features of the victron equipment. I am no solar expert but I think it would be nice to have a breaker before each panel so that any or all the panel could be isolated in the event you need to work on wiring or have a panel get damaged.
If the location of your amp meter shunt were moved to the positive lead where all the batteries connected would it also be able to account for the amps in from the solar as well as the alternator?
Ted
10-09-2019, 11:06 AM
#467
I really think you need a true isolator on the start and alt circute
10-09-2019, 11:34 AM
#468
Any time you have more than two parallel strings you need overcurrent protection on each string.
Midnite makes a "combiner box" that houses breakers for each string and combines them before the charge controller.
I think that your battery configuration is less than ideal. I heard it described well - you are "stuck in the 12v box".
There are some great stickies covering battery sizing, configuration and care over on www.solarpaneltalk.com
Good luck.
10-09-2019, 12:21 PM
#469
It was recommended to me to have a breaker between the panels and the CC.
10-09-2019, 02:01 PM
#470
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Any/all types of circuit protection is a good thing, IMO...^
"Cheap insurance" as they say.
10-09-2019, 02:14 PM
#471
We've got circuit breakers on either side of the charge controller, with a double pole breaker on the solar panels side.
10-09-2019, 05:32 PM
#472
Chassis: AARE
What could isolate more than an open solenoid?
10-09-2019, 08:14 PM
#473
I'm just being a smart a$$ but what could isolate less than a failed solenoid?
10-09-2019, 10:11 PM
#474
Good call Jack on a bad solenoid, likely messy.
10-10-2019, 08:13 AM
#475
Chassis: AARE
Well, in 55 years or so of working with things automotive I can't say I've seen solenoids fail more than a handfull of times. Never in the closed position. Usually they operate but don't make contact. Appreciate the advice but, I'm going to go with what I know and already have on this one.
I just checked with my son, who works in the RV industry and designs motorhome, he said the high end motorhomes still use solenoids.
In looking at my diagram again I see I have left off a couple of things, I'll redraw and post again.
TJones
Good catch, the shunt needs to be on the negative side, all I have to do is move the negative cable from the charge controller to the other side of the shunt.
10-10-2019, 09:59 AM
#476
I'm currently using a marine battery bank switch to manually control a connection between banks, but I have been planning to replace it with an esp32, voltage sensors, and a big solenoid to connect them automatically in the future. My experience is also that solenoids fail open.
10-10-2019, 10:26 AM
#477
Low voltage high amp can weld a solenoid contacts together. Not uncommon.
Continuous operation solenoids (make sure you understand the difference between momentary and continuous) leave opens for other things to happen. Just think a true isolator with mosfet is better than mechanical solenoids. And safer.
10-10-2019, 11:02 AM
#478
This all assumes you have an appropriate circuit breaker. If you're welding your solenoid shut you've far exceeded its rating and have likely exceeded the ratings of your wire and connectors as well.
10-11-2019, 08:45 AM
#479
Chassis: AARE
Amended wiring diagram.
10-11-2019, 09:00 AM
#480
You brought back memories of a cross country trip in a big Uhaul truck.
Out in the sticks and stopped for fuel. When I started the truck to leave the solenoid failed in the closed position. I was really surprised at how long the starter spun before it quit. I don't know if the battery or the starter failed first.
12 hours later Uhaul brought me another truck. Then I got to move all of my stuff into the new truck and carry on.
