Old 03-20-2017, 07:12 AM   #41
tobeamiss's Avatar
After taking off my strobe, it didn't appear they made any attempt to seal it, and looks like it took a few tries to finally get the strobe on there... crooked!
That's exactly the same thing in mine! It doesn't look like they tried at all. All of the rust in that part of the ceiling is coming from the hole where the wires come in for the strobe. The rest of the roof is great. Thankfully
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 03-20-2017, 01:19 PM   #42
tobeamiss's Avatar
Just as I thought...This is gonna take some work.
This is how the front section came out. Not too shabby.
So, after being down with the Flu in Feb, I really didn't feel like myself for 2 weeks...and then we had that miserable snow storm/blizzard a week ago and single digit temps which lasted like forever, I'm now finally back to work on my bus
oh yes she did!
Old 03-20-2017, 01:27 PM   #43
Man, I haven't been sick in a LONG time, till that nasty cold or whatever it was in Feb... I felt like crap for a couple weeks myself!
Glad to see you back to working on the bus. Post some more pics!
Old 03-21-2017, 04:11 AM   #44
tobeamiss's Avatar
Me too. I thought I was superwoman or something because I hadn't even had a cold for years...now I'm sick all the time. I got a cold after the Flu and now I have another cold and it's only been a month since this all started.
I'm real happy that I'm finally to the floors...last step before it all starts to happen. Demolition has taken me a long time and soon it's time to build and Spring's here and it won't be bitter cold anymore.
I'm going to do the welding myself. My sister law says that her brother has been welding for 30 years and that he'll either come over and do the welding for me or he can come over and give me a tutorial. I'm psyched!
oh yes she did!
Old 03-21-2017, 04:23 AM   #45
Wear long sleeves and a button up shirt (buttoned to the top)....
Don't ask me how I know this
Old 03-21-2017, 04:29 AM   #46
tobeamiss's Avatar
Oh boy.
oh yes she did!
Old 03-21-2017, 04:32 AM   #47
tobeamiss's Avatar
Oh boy. Hope you didn't get burned?...
I'll probably wear a zip up suit. I wear one right now when using the grinder because I don't want to get filthy from the particles and dust flying.
oh yes she did!
Old 03-31-2017, 01:41 PM   #48
tobeamiss's Avatar
Not much new to report. I'm still working on getting the floors up and finding a lot of rust. I'm treating it as I go with prep & etch.
Today I picked up some Rustoleum metal primer paint and Loctite premium construction adhesive for the corners where the floor meets the walls. I'll also be using the construction adhesive to afix some steel to cover the holes in the floor that I'm finding.
When I'm done dealing with all of the rust and painting the primer, it's on to insulation.
Moving right along....
oh yes she did!
Old 03-31-2017, 03:00 PM   #49
Keep up the good work!
Old 03-31-2017, 04:39 PM   #50
tobeamiss's Avatar
Hehe so fitting. I'm on vacay next week and I will go a little further. Hopefully alot further! Thanks!!
oh yes she did!
Old 03-31-2017, 04:48 PM   #51
- Bound to cover just a little more ground!
Old 04-02-2017, 06:32 AM   #52
tobeamiss's Avatar
Instead of welding sheet metal to cover the holes, any thoughts on using the metal ceiling sheets cut to size and using the construction adhesive? It's not the same gauge ofcourse but the holes that I've found so far are not that big. Also where the wheel well meets the floor is rusted out but again not real bad. I would treat the undercarriage side of the hole too with etch and prep, then metal primer paint before using the adhesive.
Thoughts, concerns?
oh yes she did!
Old 04-02-2017, 03:35 PM   #53
Thoughts, concerns?
sounds good to me. I'm not gonna weld all the floor holes up, I'm gona glue lil patches over em.
Old 04-02-2017, 06:30 PM   #54
tobeamiss's Avatar
Awesome. Thanks!
The holes I have from rust are no larger than 4 inches in diameter. I think I got lucky considering it's a NY bus exposed to snow and salt for 15 yrs.
oh yes she did!
Old 04-02-2017, 09:58 PM   #55
Stewzer55's Avatar
Coachwork: Fisher Body
Chassis: GM "B" Platform
Engine: 350 TBI Chevrolet
Rated Cap: 8
There are special metal bonding adhesives used in the automotive industry that would work better. Use seam sealer on edges and remove or convert existing rust.
Sent from my SM-G930P using Tapatalk
Closest I have to a Bus would be my '92 Oldsmobile Custom Cruiser Station Wagon 1 of 4,347 built.
Stewzer55 is offline   Reply With Quote
Old 04-04-2017, 06:55 AM   #56
tobeamiss's Avatar
Ok great... I'll look for and do that. Thank you.
Sent from my SM-T350 using Tapatalk
oh yes she did!
Old 06-11-2017, 01:49 PM   #57
tobeamiss's Avatar
Today we work on getting the heaters out. At the same time I'll be flushing the system. Not sure how much coolant I need but I picked up 3 gallons of Prestone dex-cool extended life antifreeze/coolant along with 4 gallons of Distilled water. I did my research here (i couldn't even tell you who's post because I'm tapatalk challenged and read so many) but I think it was on the advisement of Cadillac to use distilled water because of all the minerals etc in tap water...thank you...
I haven't a clue what I'm doing but my son is coming over and said we could do this!
It's 93° right now and I'm ready for a nap in the AC but I have to do this and since he offered well, here we go...
It'll be a nice break from working on the exterior prep for painting anyway. That's a whole other story.
oh yes she did!
Old 06-11-2017, 05:48 PM   #58
Stewzer55's Avatar
Rated Cap: 8
Dexcool is probably not the best choice coolant for your engine, It's been somewhat problematic in GM vehicles from the mid '90s and up with its tendency to break down intake manifold gaskets and sludge up. I think fleetguard is a popular choice for coolant around here and YES distilled water will work best!
Old 06-12-2017, 07:09 AM   #59
tobeamiss's Avatar
Well the good news is we didn't get to it. Everything happens for a reason
We ran into a problem fitting the hoses... I bought a 1" hose adapter only to get home and find that he sold us a 3/4". Too late to go back because they closed for the day.
Thank you for the advice, I'll make the return and get some Fleetguard.
oh yes she did!
Old 07-10-2017, 08:27 AM   #60
tobeamiss's Avatar
It is done. Actually it's been done for a while but I'm just now updating.
My brother came over and we worked out a solution for the coolant return back to the engine. We ended up using the brass (curved pipe) that was used on the heaters themselves. It's a wide loop but good because the brass pipe has flanges on each end. Also used the heavy duty clamps that were on the heaters.
Instead of doing a Flush with the distilled water, I just drained all of the coolant. We ran out of daylight so the next morning I filled it with the Fleetguard (thank you Stewarz66) mixed with distilled water. I couldn't believe all of the crud in the old stuff so I'm real happy I did this. I let it run for about 30 minutes and the temp gauge never went over 120.
Moving on...I now have all of the rust gone and/or treated, holes covered and smaller holes plugged and I'm ready for insulation. I'll be using spray foam so while I'm waiting for that to come in, I'll continue work on the outside. I have all holes patched, and most of the exterior sanded. This week I'll be on the roof caulking and prepping for paint. I got Henry's sealant, and a couple cans of elastomeric paint.
I feel like I'm working at a snails pace. If it wasn't for all rust on the floor and adhesive from the reflective tape I'm sure I'd be much further along.
oh yes she did!
