12-16-2014, 11:31 AM
#21
Re: Yet another "is this a good deal" thread
Yeah, that's kinda how I'm thinking. I can think of way worse ways of pissing away money than buying buses!
I hope you understand that I wasn't trying to be too pushy or anything. I'm just very opinionated at times, especially if asked for an opinion!
12-16-2014, 11:35 AM
#22
No worries! I came here asking for opinions. Honesty is exactly what I was seeking! As the saying goes, "there's an ass for every seat". It looks like my ass (or my seat?) is a bit more expensive than yours, that's all.
12-16-2014, 12:56 PM
#23
That's funny.
Cheers, enjoy the bus and may it provide you lots of happy, trouble-free miles.
12-16-2014, 03:17 PM
#24
Originally Posted by boojiewoojie
[...]Also curious to know what the hours are. If it's in the 6000 range that's about normal. [...]
Just heard back. 9400 hrs.
And just found out the gear ratio in the back. It's an unsurprising 5.63:1
12-16-2014, 03:23 PM
#25
That's a high amount of hours.
I don't know much about the 3060 as its got a "brain", but the rear ratio sounds like it wouldn't be fun out on the highway.
12-16-2014, 03:26 PM
#26
Yeah, the hours certainly are on the high end. By my calc, it looks like with that gear ratio on the 3060, I'm maxing out at 67mph in 5th gear and 78 in 6th (after I get it unlocked).
12-16-2014, 03:30 PM
#27
Hell that's plenty quick. I get 62-65 max.
I just have to share this one, I know you won't like the FE part, but this one I would be all over if I didn't already have a huge project on my hands.
http://www.publicsurplus.com/sms/auctio ... uc=1269578
Its got all the good running gear and is all mechanical. An All American.
12-16-2014, 03:33 PM
#28
I'd be bidding if it were RE.
#29
Here is a member on this forum who says he may be selling a rear engine Crown Supercoach II. viewtopic.php?f=9&t=6351
And since you don't mind paying retail- here's a nice looking bus on ebay. Clean TX bus. Cummins 8.3. http://www.ebay.com/itm/1998-Thomas-Saf ... 1446154745
12-16-2014, 04:50 PM
#30
No headroom there.
I did find an AmTran RE. He wants $6800 but I presume that's negotiable (isn't everything?).
1999 International AmTran RE
84 Passenger
DT466E 230HP/660lb*ft
MD3060 CR (Not sure what the C is, but the R's retarder, no?)
Air brakes
78" Headroom
105 Gallon tank
Cruise Control
Rear air suspension
Another AZ bus - so rust free.
Miles ~202k, not sure about the hours.
http://phoenix.craigslist.org/cph/cto/4807936298.html
12-16-2014, 06:21 PM
#31
I know I wish I had cruise control. Find out the hours. Way more important than the miles.
check this list too! http://www.tampabusmarket.com/inventory
12-16-2014, 07:14 PM
#32
Between the IH and Thomas I would lean toward the IH everything else being equal. I have many hours driving both and have owned both. Currently own a newer version of the IH and also driving a '98 IH on my route. (The '98's a dog with the 444E) Main reason is the 466E is much cheaper to overhaul. $1100 for an inframe rebuild kit, oil cooler for ~$350, filters and fluids replaced for ~$200 and whatever labor charge you go with (unless you want to tackle it yourself!). Resurfacing the head is also pretty cheap. Engine is more accessible on the IH also. And the engine layout with the radiator at the back is simpler. The only downside with the engine bay is the air intake tunnels intrude more on the bus interior- you can't put a bed above the engine bay.
Visibility out of the Thomas is a little better out of the side window. The Thomas probably has adjustable steering wheel height while the IH probably doesn't. Looks like the IH may not have air door since it opens inward. They all vary as far as noise but the IH seems to be a little "tighter". If the Thomas has rear air ride they'll both ride about the same. If the Thomas doesn't have air ride it's a no brainer for sure.
With 202k miles the hours are probably around 9000 so about the same there. Are the mileages the same on the other 3 buses?
As far as negotiable- $4000 would be a nice price.
And the Tampa place may have some good buses. Sometimes they don't answer the phone however.
Daddy, can we go on a trip again??
'85 Thomas SafTLiner RE
3208 NA CAT MT643
12-16-2014, 07:22 PM
#33
Also, check with Tom Buhle at Midwest Transit in Whitestown IN. He was supposed to have some more RE's come in this month. The only problem there is they will have some rust. Nothing structural. And the mileage/hours will probably be low, and they should be 2002/2003 models.
3208 NA CAT MT643
12-17-2014, 01:25 PM
#34
12-17-2014, 01:29 PM
#35
For anyone out there who knows.. is the white knob to the left of the steering wheel for an air door?
12-17-2014, 01:36 PM
#36
13k hrs=about 650k miles.
Don and Mary
12-17-2014, 02:01 PM
#37
Perhaps this is just how it goes in a bus hunt, but turns out the IH *doesn't* have a retarder. It has an MD-3060/CR which I erroneously assumed meant retarder. Turns out it's Close Ratio. Dang.
12-17-2014, 06:06 PM
#38
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Self,
Yes that's the air powered door switch you have pointed at. However, there is also an override switch near the ignition switch as well. Hope this helps.
M1031
12-17-2014, 06:41 PM
#39
Ooooouch! 13k hours... Next...
That is seriously high time.
3208 NA CAT MT643
12-17-2014, 08:04 PM
#40
Yeah, at this point the IH is going to be a negotiating tool to try getting the Thomas for less. 13k hours, with 12x,xxx miles, a close ratio transmission, and a 55mph governor all say: *lots* of city driving when not idling. Booo.
