Old 10-18-2019, 08:03 AM   #1
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Allow uploading webp images
GIF has some serious limitations, most modern web browsers now support webp images which are higher quality and smaller size. Its not linear, but generally I can make webp images quadruple the resolution, double the framerate and twice the length for the same file size.
I would upload a comparison, but it isn't allowed. Its a fairly overwhelming difference.
kazetsukai is offline   Reply With Quote
Old 10-18-2019, 11:06 AM   #2
Janet H's Avatar
Thanks for the suggestion - taken under advisement. Currently you can attach files with the following extensions: gif jpe jpeg jpg pdf png psd txt bmp.
webp is still not fully supported by Edge and so this causes viewing issues. Perhaps biggest issue is that this boards CMS isn't compatible - images would not display a thumbnail - just a black box. In the coming year we'll be changing software platforms and accommodating webp should be possible.
You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose | Dr. Seuss
Janet H is offline   Reply With Quote
Old 10-18-2019, 11:09 AM   #3
kazetsukai's Avatar
Rated Cap: 76
AFAIK Edge is switching to a Chromium based backend, and should support it.
As a workaround, you could allow the extension to be uploaded as a raw file, then I could use the link to the file to populate an "image url". It would be two-step instead of one step, but it might work?
Either way, thanks for the consideration!
