Old 04-09-2023, 12:29 PM   #1
Nordmann's Avatar
Coachwork: International Navistar 3800
Chassis: International Navistar
Engine: 7,3l turbo diesel
Rated Cap: 26 seat and 2 wheelchair
Chassis fuse
Hello everyone,
one of my first problems is that I don't have a record of the chassis fuse box on the left side. Access is from the outside on the driver's side below the driver's window. I drive an international Navistar 3800 from 2001.
I'd be happy for help.from 2001
Greetings Nordman
Nordmann is offline   Reply With Quote
Old 04-09-2023, 12:53 PM   #2
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Navistar Manuals
Not a circuit diagram, but this link may help you.
https://www.manualslib.com/brand/navistar/engine.html
Old 04-09-2023, 03:59 PM   #3
on a 3800 there are 2 fuse panels.. the CHASSIS fuse panel is on the dashboard behind a little black cover.. this panel will have things like your engine computers, brake lights, head lights, turn signals, transmission modulator / controller etc..
the BODY fuse panel will be in different places depending on the manufacturer.. your body may be an Amtran / International, bluebird, thomas, or possibly a Crown by carpenter.. that fuse panel is either on the outside of the bus under the drivers window or is behind the switches..
where you go to look for info depends on which fuses you need help with..
chassis fuse
