Old 01-18-2021, 11:31 AM   #1
Fresh Water Check Valves
Hello all! Plumbing my fresh water system and have a quick question on check valves. I will install a check valve after my pressurized freshwater (campground) hook-up. Should there also be one installed after my tank water pump and accumulator, before I 'T' into the pressurized (campground) line? If I do not do this, is there a chance the pressurized (campground) line could feed back through the water pump and into my tank?
Sorry if this is a novice plumbing question.
Thanks!
jwvicker is offline   Reply With Quote
Old 01-18-2021, 11:51 AM   #2
The chance is there and is avoidable simply by the use of a second valve. For me, at least, remembering to set the valves seems to be the tough part.
Old 01-18-2021, 12:56 PM   #3
I also have two valves and two check valves just valves. Belt and suspenders!
Old 01-18-2021, 02:50 PM   #4
Thanks - yes, makes sense to me too.
check valve, freshwater, plumbing, pressurized
