Old 07-06-2021, 04:54 PM   #1
Hitches
How or where do I post about getting & putting a hitch on my bus?
Thanks,
HDTB is offline   Reply With Quote
Old 07-06-2021, 05:02 PM   #2
What’s your bus? Some get lucky and find a factory made hitch that fits. Others go to a custom maker. If you know your frame rail spacing you can try etrailer.com
Old 07-06-2021, 06:11 PM   #3
With a welder and a grinder, everything is possible. I made my own for a fraction of what one would cost retail.
Old 07-06-2021, 07:29 PM   #4
Chassis: Ford E450
Engine: V10 Gas
There have been a couple of design threads over the last year or so regarding receivers, rated capacities, general towing considerations. I think searching for GVW (gross vehicle weight) or 'tow' will bring them up.
My bus is a shuttle and I got a little spooked by talk of undersized transmissions; still, I'm fabricating a rear deck and receiver using 1/4" wall 2"x3" stock.
It is strong enough to tow anything, I think; but whether the engine and tranny will last is still an open question.
I've seen more pictures for design ideas in the various FB groups (but don't expect meaningful discussion about actual load design over there).
Old 07-07-2021, 08:04 AM   #5
Chassis: IH 3800
You need to know the width of your frame... and then you need to find a work body or cab and chassis hitch that will fit your frame width. They aren't too expensive and are typically Class V or higher.
This is the one I'm running currently. They make different height side rails and as you can see, its somewhat universal.
https://www.draw-tite.com/product/41...-trailer-hitch
Old 07-07-2021, 08:40 AM   #6
Chassis: Vista 3600
Rated Cap: 24000 lbs
I made mine.. and it serves 3 functions
It holds a KE100 motorcycle on top
The Onan 4k Genny tucked up under the bus so it's also the genny mount
as well as a tow hitch
https://www.skoolie.net/forums/f10/t...sta-32691.html
RolesvilleMarina is offline   Reply With Quote
Old 07-07-2021, 12:47 PM   #7
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
Do the side plates come pre-drilled by default? The website isn't clear as to whether the side brackets have holes ready for the bolt-on "option" that's mentioned in the instructions.
dbsoundman is offline   Reply With Quote
Old 07-07-2021, 12:49 PM   #8
Chassis: IH 3800
Yup. Here is a link showing the plate options.
https://www.etrailer.com/question-9969.html
