01-27-2020, 09:57 PM
Internet category?
I've searched the forum and not found anything about Internet. Since i will be working full time from my bus (Indie author and publisher) I will have to have good internet. I'm trying to find all the right components and setup for that. Like the Verizon Jetpack, various antennas, the setup in general, and how much solar I'll need to run it and my computer, monitor, etc. I didn't see a dedicated forum area for this. Did i miss it?
01-28-2020, 01:52 AM
Chassis: fs65
Engine: 7.2 catapillar 3126
Rated Cap: 41 students
There are forums dedicated to nomads who have mobile internet setups... I wouldn't limit myself to searching just this forum.
Google is your friend.
@drivingdharma
01-28-2020, 06:51 AM
I carry a Verizon Jetpack, and AT&T unite Pro, and a Tmobile SIM in a MikroTik LTE router.. granted I dont live in a bus.. I am a road warrior and do all kinds of internet stuff (owner in a couple Internet Telephony companies)..
I carry all 3 because I find certain areas of the country are better than others for each carrier's signal.. I can write them off too since Internet is required for the business..
01-28-2020, 01:16 PM
I have recently switched to Verizon's Visible service. As low as $25 a month for unlimited data and talk. I have USB tethered it to a Gl.Inet router. Works great most places. However, I had intended to replace my AT&T hotspot ($35 a month unlimited) with the Visible but have found places that I frequent that it has no service that AT&T does. Overall the Visible service has better coverage. With both of them onboard we get coverage most places that we go.
I have two spots available on my "Party Pay" plan if anyone wants to join us.
01-28-2020, 06:21 PM
thanks for your input. I have seen several people who have more than one provider for the reasons you say.
01-28-2020, 06:22 PM
I was searching this forum, so that I could find other people who are doing what I'm planning to do.
I am aware of Google, yes. thanks.
01-28-2020, 06:24 PM
Haven't heard of Visible. will check it out, thanks. And yes, it seems many people have two providers. I'm seeing that a lot. thank you for your input.
01-29-2020, 12:58 AM
Chassis: fs65
I have been using my cell phone with a sure cell extender pretty successfully. I've recently read about obd connectors from T-mobile that offer wifi... I wonder if the tech in that little black box is better than my phone, given staying on the same network.
Ive read as an example Verizons jetpack being better than their cellphone...
@drivingdharma
01-29-2020, 03:14 AM
As I understand it, your rate (and everyone in your party) goes down when another is added. Tell me, what happens when one of your party bows out, leaves the party?
01-29-2020, 07:13 AM
You add a new person.
There's a subreddit ( https://old.reddit.com/r/visiblepartypay ) where you can post your group or join someone else's. There's no reason to limit it to people you know, you aren't tied together in any way.
I'm in a group with 3 people I don't know. Hillary is in a different group with 3 people she doesn't know.
01-29-2020, 08:38 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
The most important question that I can think of is "Where??"
Obtaining a good Internet from a campground next to a city is much different than 50 miles off the nearest paved road in the mountain west.
01-30-2020, 05:42 PM
Yes, i understand boondocking is different than being near free wifi at a campground. That's sort of the point. I will be traveling all over, and mostly boondocking, and I'm trying to choose the best set up to do business reliably. Whatever that is. Like, it seems that the Verizon jetpack, and a boosting antenna might be the way to go.
01-30-2020, 06:49 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Well, if taken literally, I have some bad news for you. There are some huge expanses of space here in the west where cellular connectivity is non-existent. Verizon has the best coverage in the semi-remote areas out here (west). I have high hopes for StarLink. Until then...
I used a Wilson Sleek ( some details here) early on and it worked reasonably well if I wasn't too remote (couple miles off the beaten path). An external antenna helped ( some info here) but it is fairly limited.
As I became more adventurous, I had to spend more money on the equipment. I've been able to pull in signal from as far as 16 miles (nearest cell tower) using this weBoost Connect 4G-X system. However; the antenna had to be quite high (30').
This is a semi-permanent install of that weBoost antenna.
Height is key. RF signal is line of site. If you are in a low area (with hills/mountains around) the signal is most likely not getting to you (assuming the towers are miles away). It's also worth having a mobile setup. There were times I would spend a whole day scouting an area in my Jeep with my mobile antenna setup looking for a good boondocking spot WITH Internet.
Things are changing fast in this space so there is probably new equipment (I haven't looked in the last year). However; if you plan to get out in remote areas (in the west) and work, you'll need much more powerful equipment than the norm.
01-30-2020, 07:03 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
01-30-2020, 08:38 PM
We've got a Verizon jetpack with a Weboost 4G OTR booster. We've also got a 18' telescoping pole to attach the antenna to. We don't deploy this too often but it's nice to have and sometimes its the difference between internet and not. Like JD, we boondock pretty much exclusively, and have been in the soutwest for a few months now. We mostly go to places that are reported to have service (we use Campendium to find the general area, then scout around). Sometimes we're in areas where the tower is overloaded, or our service gets throttled back, and it's abysmally slow. Sometimes it's lightning fast. We tether to our phones sometimes if the jetpack is slow. Depending on what type of work it is that you do, a setup like this might work for you. Wouldn't be a bad idea to have a couple different providers if you've got it in your budget. I know there's routers that take multiple sim cards.
If the signal isn't strong enough for you, you can always move to another spot...that's one of the benefits of bus life!
02-03-2020, 07:46 PM
Thanks for pointing this out! There is a new forum section now based on your request Mobile Tech | Phone, Internet & e-Gadgets - School Bus Conversion Resources
BTW - I use a weBoost Drive 4G-X OTR mounted on a (telescoping) pole. it's the best solution I've found to date and marginally acceptable.
You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose | Dr. Seuss
02-12-2020, 10:48 PM
Originally Posted by Janet H
OK, good to know that this is a new forum section. I was beginning to question my sanity. I know, the two are not necessarily mutually exclusive.
While we're about it, could I request that alt fuels be merged with veggie oil? Between the two, they don't see enough traffic to be worth it. Just a thought.
I do not suffer from mental illness. I enjoy every damn minute of it!
02-14-2020, 06:07 PM
Also done - good idea.
