Old 03-05-2016, 09:29 PM   #1
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
Link to build thread in signature
I have seen other users have links to their build threads on here in their signatures, but when I try to use the BB code URL or THREAD, it says it is not allowed. I can understand not wanting external links to some degree, but linking to a thread here would seem to be mostly harmless. Mostly?
My project: The Cruel Bus
RHOMBUS is offline   Reply With Quote
Old 03-06-2016, 05:56 AM   #2
I've never figured that out, either.
Old 03-06-2016, 11:19 AM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I have a link in my signature. I do not think it is because you are not allowed but because you are not using the right format to post the link...maybe?
I'm hungry!
You Gotta Let Me Fly
Old 03-06-2016, 02:45 PM   #4
RHOMBUS's Avatar
Do you remember how you did it, crazycal? Maybe when you first made the link it was allowed and now it's not? Could you copy and paste the code you used here?
Old 03-06-2016, 04:20 PM   #5
Moderator
crazycal's Avatar
I will try later tonight.
I'm hungry!
Old 03-06-2016, 04:43 PM   #6
turf's Avatar
it is in the user control panel, edit signature
make sure you're signed in, pick "user cp" at the top of the page
Turfmobile Build Thread
Old 03-06-2016, 05:58 PM   #7
RHOMBUS's Avatar
turf: I did all of that but the actual html code and BB codes are refused by the bulletin board program.
Old 03-07-2016, 04:39 PM   #8
Janet H's Avatar
I got this set up for you - the signature section of member profiles isn't very friendly...
Build Project: Serenity | 2002 Thomas HDX
You have brains in your head. You have feet in your shoes. You can steer yourself any direction you choose | Dr. Seuss
Janet H is offline   Reply With Quote
Old 03-07-2016, 04:49 PM   #9
RHOMBUS's Avatar
Thanks, Janet
Old 03-07-2016, 05:04 PM   #10
Could someone please help ME out??
ROLL YOUR OWN... needs a bit of help twisting this one up!
Old 03-09-2016, 02:23 AM   #11
gizmoq's Avatar
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
Can't get mine to accept BB URL Code.
The more I do, the more I find needs done.
____________________________________
Build Thread - ET - ELWOOD Transporter
gizmoq is offline   Reply With Quote
Old 03-09-2016, 04:52 AM   #12
Still waiting.
Old 03-10-2016, 09:44 PM   #13
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
It'd be nice if the signatures were set to allow bb code links after the user has maybe 100 posts or something.
wunderhut is offline   Reply With Quote
Old 03-11-2016, 06:44 AM   #14
CB paste this in your signature line, other just modify it
[URL="http://www.skoolie.net/forums/f11/roll-your-own-9771.html"]Roll Your Own
add this to end [ / U R L ] remove the spaces in between brackets so it looks normal
Old 03-11-2016, 07:20 AM   #15
Nope no luck, thanks anyhow Bansil.
I wonder why Janet, when reading through, chose to help Rhombus but not me.
Old 03-11-2016, 07:45 AM   #16
cb look at my sig line now
all I did was take out extra wording and added this to end [/url]
I copied whole post to notepad and then
I removed:
add this to end
and removed spaces in bracket, then copied and pasted into sigline
Old 03-11-2016, 07:50 AM   #17
here's what I'm getting-
BB code url is not allowed.
Old 03-11-2016, 08:01 AM   #18
I don't have access to edit your profile, I will see if I can get it done
Old 03-11-2016, 08:36 AM   #19
http://www.skoolie.net/forums/f11/ro...-own-9771.html
Roll Your Own
Old 03-11-2016, 08:46 AM   #20
turf's Avatar
out of curiosity i just looked at mine again.
i believe the options on the signature dialog box have changed. when i did mine there was an insert link button. it was simple.
now looking, i no longer have that button on the signature dialog box.
fwiw
