Originally Posted by CalC
I would love to find someone with experience as a bluebird mechanic to help me and give me advice as I work on a 2000 bluebird LTC40 doing the radiator and hydraulic drive fan motor replace.
I am a farmer rancher mechanic that can do a lot but I need good guidance and usually get that better from talking to people
This Bus is a passenger bus used for hockey lacrosse and baseball will seat about 43 people and is based on same bus as Wanderlodge by Bluebird.
Hydraulic pump attached to the transmission pumps Dextron 3 Automatic transmission fluid to power the steering and the engine cooling fan motor. This bus also has a 2-12 fans powered by 12 volts. On a Hayden cooling fan for the hydraulic oil, on the left side of the bus in front of the radiator. Both pass air through the left rear side of the bus.
