Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 01-08-2022, 12:42 PM   #1
No plywood subfloor... Only Metal
Hello, this is my first post, so advance apologies for any forum etiquette mistakes of mine.
In April of 2021 I purchased my 40ft Carolina Thomas school bus, Cummins front engine. She's a beaut.
My boyfriend and I have been gutting her since (the seats had already been removed but the previous owner had begun putting in wood on top of the rubber floor and building a structure, so we had to re-gut).
We began removing the floor only to find out the rubber is directly glued to the metal, there is NO plywood in between. Click here to see what I'm talking about.
The floor is pretty un-rusted, but we can't figure out any other way to remove the floor other than chiseling away at it, piece by piece. Have you guys got any ideas?
absgeller is offline   Reply With Quote
Old 01-16-2022, 02:39 PM   #2
HEAT.
Either a torch or electric heat gun will soften the rubber and adhesive.
ChrisKatana is offline   Reply With Quote
Old 01-16-2022, 03:32 PM   #3
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Heat gun from Harbor Freight is about $20. If yo have compressed air with a bit of volume you can also get an air chisel with wide blade for like tile removal. A little heat and that chisel should make short work of the rubber.
ONLY YOU can ensure your safety! . . . . . We've done so much, for so long, with so little, we now do the impossible, overnight, with nothing. US Marines -- 6531, 3521. . . .Ret ASE brakes & elect. Ret (auto/aviation). Extra Class HAM, NAUI/PADI OpenWater diver
HamSkoolie is offline   Reply With Quote
Old 01-16-2022, 03:59 PM   #4
It's a bit late for this, but if I got a bus with no plywood I would just leave the rubber layer in place and build my subfloor on top of it.
Old 01-16-2022, 04:55 PM   #5
if the metal is in good shape then musigenesis has it right dont pull the rubber.. and chznces are the metal on a non-wood bus is a LOT nicer than one with wood.. plywood is optional when buying new busses so some have it some dont..
Old 01-16-2022, 06:29 PM   #6
That's what I thought. glad I pulled mine out. I found tons of rust under the rubber. Left untreated would have been catastrophic.
floor, floor removal, interior, metal, rubber
