Old 05-08-2020, 08:02 AM   #1
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Occasional problems uploading images
Firefox 75.0 FWIW.
POST to newattachment.php occasionally yields an SSL_ERROR_BAD_MAC_ALERT. Upload window says "Uploading File(s) - Please Wait", failing silently.
May need to update your SSL certs, may be non-SSL related entirely if erroring server-side. Can't know without seeing the logs. Time this happened: 8:50 ish EST so you might see something then.
kazetsukai is offline   Reply With Quote
Old 05-09-2020, 07:16 AM   #2
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
I doubt it would get far enough to generate an error in either case, but you might check the dimensions of the files you were trying to upload, and the format, because there are size limitations and I don't think all image formats are supported either.
