Old 09-13-2024, 07:10 PM   #1
Kliddel1's Avatar
Year: 2010
Coachwork: Thomas mvp ef
Chassis: Flat nose
Engine: Cummins ISL
Rated Cap: Class 7:26,-33000lbs.
Trans issue
I have 2010 Thomas flat nose with the T-handle gear shifter. There is a red light (small red dot) left side of shifter and bus acts like it's in neutral in every gear. I put about half gallon of ATF in still doesn't move light still on.
Kliddel1 is offline   Reply With Quote
Old 09-13-2024, 07:50 PM   #2
ewo1's Avatar
Step on the gas pedal real hard !!!
Old 09-13-2024, 09:27 PM   #3
Kliddel1's Avatar
Year: 2010
Chassis: Flat nose
Engine: Cummins ISL
While bus is running and in gear??
Old 09-14-2024, 10:27 AM   #4
ewo1's Avatar
No man, i was just messing with you…
Check your emergency door switches/wheelchair lift too. The wheelchair lift will either apply brakes or keep trans in nuetral depending on how it was wired/ordered.
What tranny you got in the bus?
Old 09-14-2024, 12:28 PM   #5
Kliddel1's Avatar
Year: 2010
Chassis: Flat nose
Engine: Cummins ISL
Lol, desperate would try anything. I assume Allison but not 100% sure will check
Old 09-15-2024, 09:44 AM   #6
Stovebolt's Avatar
Chassis: International RE300
Yeah, the ole wheelchair lift door trick ... that one got us a good one during the paint job. My boss has to move the bus (while it was being painted) and couldn't get the brakes to release. He called me. I asked if there was a buzzer going off, too. He said yes. I told him to check to make sure ALL the doors and emergency windows were secured.
Yup.
Stovebolt is offline   Reply With Quote
Old 09-20-2024, 11:45 AM   #7
ewo1's Avatar
Well, did you get it fixed or what ???
