Old 04-19-2024, 11:47 PM   #1
Adapter for water inlet
My fresh water inlet is 1.6 ( link below).
) but my tank inlet is 1 3/8". Do you just choose 1 3/8 hose pipe in this case and some sort of adapter; to reduce from 1.6 to 1 3/8? I can't seem to find adapter from that. Any thoughts?
https://www.amazon.ca/Locking-Freshwater-Lockable-Leakproof-Motorhome/dp/B0BVG894FP/ref=mp_s_a_1_2_sspa?crid=1OZLL8GHXZDML&dib=eyJ2Ijo iMSJ9.VS8qqZxZfiNbOvtK8JoaasI1jSAu2v5QfxPJ97QdRfwj 3Z83M-EDaAllZ5bUcZlOtOR9wMorLHge5pGIFbYanHsKPmh8CPEs4R6j l_q_Z1834yp3clSPslvTWGeTO1OD12ni3dMIMXSfkmri8EyE3C J4qY1Y-2teLXTSP3bSemSVcGgm7fFT1YHEwdicvsmtQ7XlZhqWb1hSbLT _UeeZQQ.rqbexzVdD3klZ0vhZabxbiTLdBz4ejuzzbRyNm60J-8&dib_tag=se&keywords=Rv+water+inlet&qid=171358794 8&sprefix=rv+water+inlet%2Caps%2C160&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfY XRm&psc=1
kowalewska.ka is offline   Reply With Quote
Old 04-19-2024, 11:58 PM   #2
fo4imtippin's Avatar
Chassis: TC2000 28ft
I had a similar problem where my inlet was 1.5in OD and my tank had a 1.25 neck. I have a few inches of hose on the inlet and then I have a 1.5>1.25 reducer going to a 1.25in hose.
Old 04-20-2024, 12:05 AM   #3
Was it difficult to find the adapter? Did you get it in regular construction shop? Or had to go to rv plumbing shop or so?
Old 04-20-2024, 12:11 AM   #4
Below are the products I used. Most of this type of stuff I have gotten off Amazon.
ANPTGHT 1-1/4" to 1-1/2" Inch Hose Barb Splice Coupler Repair Fitting, Aluminum Adapter Connector Radiator Coolant Intercooler Heat Exchanger Fluid Designed (1 pcs) https://a.co/d/eghcKrM
Meprotal Boat Deck Fill/Filler 1-1/2"(38mm) Water Deck Fuel Filler Angled Neck 316 Stainless Steel Hardware with Key for Boat Yacht Caravan (Universal) https://a.co/d/e6XepvX
QuQuyi 1-1/2" ID x 1-3/4" OD, 1FT length Steel Wire Hose PVC Vacuum Tubing (with 2 Stainless Clamps), Drain Hose Vinyl Suction Tubing Flexible Tube Vinyl Hose Line https://a.co/d/hbnFffw
PEISONGFEI 1 1/4 '' ID x 1 1/2 '' OD Heavy-Duty Steel Wire vacuum Suction Flexible Hose High Pressure UV Chemical Resistant Thick Vinyl Tube, Bilge Pump Hose,10FT https://a.co/d/8cXI6wT
Old 04-20-2024, 08:59 AM   #5
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
That's a lot of chinesium.
I generally try to avoid putting that kind of stuff in critical systems.
Albatross is offline   Reply With Quote
Old 04-20-2024, 10:30 AM   #6
What would you use instead?
Old 04-20-2024, 05:19 PM   #7
Chassis: Chevy P30
American or Mexican -made parts.
Or I would make them myself, since I've got a machine shop at my disposal and the skills to use most of it.
