Old 11-16-2020, 05:00 PM   #1
Air Brake Help
Hi, friends. First post here.
I just bought an 82 Thomas diesel pusher. It starts and runs like a dream. Problem is the air brake compressor needs repair or replacement.
The seller was super helpful and even showed me where to attach an air hose to pressurize the tanks with a portable gas powered compressor, which I will need to do to move it.
My conundrum is he said I'd need 150 psi to do the job but I can't find anyone who rents such an animal.
Does that pressure sound accurate?
Ski Patroller Geo is offline   Reply With Quote
Old 11-16-2020, 05:08 PM   #2
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
20-40 psi to release the spring brake for towing.
60-85 to deactivate the low air warning if key switch needs to be on (unlikely for towing).
90-120 is normal system pressure for driving.
150 is system limit (safety valve relieves pressure to 90-120).
I recommend you have it towed for repair or repaired on site. Do NOT drive with an air system problem -- it is unsafe.
Old 11-16-2020, 05:16 PM   #3
Eeeexcellent. Thanks for those numbers.
Also, I'll heed your towing advise.
Old 11-17-2020, 07:26 AM   #4
If you're having it towed, let the tow company and driver worry/handle it. They can tow it to their shop and repair the compressor for you then.
My build: The Silver Bullet https://www.skoolie.net/forums/f11/p...llet-9266.html
Booyah45828 is online now   Reply With Quote
Old 11-17-2020, 07:34 AM   #5
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Yeah, I was going to say, do not attempt to tow this thing yourself unless you are qualified and have the right equipment, it probably needs a Class 7 truck with 8-10-ton boom, minimum.
