Old 05-28-2018, 07:51 PM   #21
Year: 2008
Coachwork: ICCO RE300
Engine: Base - L6 - 7.6L 7638cc 466ci DIESEL MFI
Let's see if I can finally share pictures. This shows the mechanism above my door that uses air pressure to open the door. As I'm removing the ceiling panels and replacing the door I had to disconnect the wires to get the panels out. Since I move the bus to work on it the gauge still showed enough pressure for me to move it back and I thought everything was fine.
The next day when I went to move it the gauge wouldn't show the pressure rising. Fortunately it was a simple as reconnected the ground wire (the white one hanging down in the middle of the picture) to the ground (copper colored blob towards the upper right area.)
AMDenels is offline   Reply With Quote
Old 05-28-2018, 08:01 PM   #22
Originally Posted by AMDenels View Post
I think that ground wire must have had something to do with the gauge itself. I couldn't release the parking break because the gauge was reading as too low. Once I reconnected the ground wire the gauge shot up showing the pressure was high.
i could see an electric interlock based on the physical position of the gauge needle as a way to determine if the bus will release the parking break or not. Its almost a double failsafe - the bus needs to have air AND a working gauge - even if the gauge doesn't work (but theres air), you can't ignore it and drive anyways.
