09-18-2020, 06:19 PM
Alternative materials for skinning over windows?
I've seen a lot of people buying sheet metal to cover over their windows. I've also noticed a lot of commercially available Coaches, and RVs dont usually have metal siding at all.
Is there a cheaper, lighter material that can be used other than metal?
Preferably something that can be easily painted along with the metal parts so you cant notice, and hopfully providing insulating properties?
09-18-2020, 08:46 PM
I started out with plywood and soon went with metal. Maybe something like polycarbonate would work but I doubt it. Metal is easy to work with and it's easy enough to add insulation behind it.
10-28-2020, 05:57 PM
Chassis: International CE
Engine: T444e
Is there a reason the plywood didn't work out for you? I'm contemplating this now as a temporary skinning until metal falls from the sky to do it right. I have plywood on hand already and with an 11 window bus I don't want to spend the extra cash right now for the metal if I play to rearrange what windows need deleting later.
10-28-2020, 07:26 PM
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
I keep (well kept now that I have a Winnie so no longer contemplate the hurdles associated with a skoolie at least for the time being) imagining instead of great long sheets of metal covering an entire section of windows I would have preferred sheet metal bent and formed into window-sized panels which could substitute one each for each removed window. Since I have never actually done this the idea is only hypothetical but it would accomplish for you the same thing it was for me, mainly that I was unsure of my final floorplan and wanted to be able to delete a window but possibly re-add it again if something more complicated caused a mid-build revision. I'd be happy to share the diagram I came up with to cut and form window-delete-inserts as I called them. Now I'm on the other end of the spectrum, my Winnebago was a mobile showroom so has no windows at all!
10-28-2020, 08:27 PM
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Just my $0.02, but using anything other than steel to skin over windows kind of defeats the purpose of it being a bus. Most of us convert buses for the added safety and crashworthiness of the steel construction, not to mention they are not quite as weak prone as a typical RV. There's an old saying, "Do it right, or do it twice."
10-28-2020, 08:50 PM
Chassis: Ford F53
I would agree that the safety factor weighs into the school bus buying decision but the windows weren't integral to the overall structural rigidity so substituting them with another lesser material isn't a compromise. I do however like the uniformity of using steel in addition to agreeing that 'do it right or do it twice' applies in this case.
10-28-2020, 09:00 PM
Year: 98
I think most people get on school buses because they are so cheap to start with and then there is the cute factor or nostalgia factor. There is a kick to be able to buy something that big for so little. They do realize that a lot of money and work has to happen. That reality sets in much later. The safety argument comes in to help justify the purchase. With the amount of conversion related accidents...grinder disks...rust dust... it would be interesting to see some of those health hazards... After all most skoolies drive less then 5000 mile / year..so the safety is very limited.
Only Chris uses his buses for daily use taking advantage of the increased safety of an Uber size vehicle.
Johan
10-28-2020, 10:56 PM
Engine: DT530
We used DuraPlate to cover our windows (google it). You see it every day and don't even think about it. It is what the sides of all Wabash National semi trailers are made of. It is simply plastic sandwiched between two thin sheets of steel. It is crazy strong.
I wanted some to rebuild my storage area so I called around last week to some semi fleet service places. 360 Fleet Services near me gave me for free 12 sections of semi walls that are 8'x8'.
Attachment 50499Attachment 50500
10-28-2020, 11:04 PM
An inexpensive method is to make your own fiberglass sheet, and then make a foam sandwich, use luan plywood for the inside if that is the look you want inside.
Youtube will show you how. Could even make one super long single piece for the whole side if you are ambitious or just do each window area.
10-28-2020, 11:09 PM
Chassis: Ford F53
Attachment 50498
You read my mind! I am totally going to contact 360 F.S. when I get ready to reskin the Tin Winnie! Last time I was over there on business I casually asked and that's exactly what the guy said, use Wabash DuraPlate. Every time they mod or salvage a trailer there's probably tons of reusable sheet metal and that's probably the least reusable thing for them except for the occasional patch job. Don't ask me why but they had whole 20 foot sections of trailer just sitting there where they'd shortened 53' to I guess 33' because I guess if you need a shorter trailer and you have unused longer trailers the mod is still cheaper than buying new 33s!
10-28-2020, 11:28 PM
Engine: DT530
Places are happy to get rid of used Duraplate. It can't be recycled so it has to be cut up and hauled away to a landfill.
10-29-2020, 12:24 AM
Interesting product!
Here is a product brochure ... a fair read. Does have some marketing fluff.
DuraPlate Overview (PDF)
Here is the fabrication guide. Now here is the stuff skoolies dream about.
Working with DuraPlate (PDF)
The Overview states that DurPlate is 100% recyclable ... so don't tell 360 Fleet Services!
10-29-2020, 12:44 AM
It’s probably recyclable like styrofoam and those tetrapak food boxes are recyclable, meaning it’s possible enough that they can say so, but economically prohibitive.
