Old 06-09-2021, 09:26 AM   #21
Chassis: IH 3800
Originally Posted by mmoore6856 View Post
(3)*The*parking brake system*shall be held in the applied position by energy other than fluid pressure, air pressure, or electric energy. The*parking brake system*shall not be capable of being released unless adequate energy is available to immediately reapply the parking*brake*with the required effectiveness.
Read section 3. Don't do some thing half-ass that might get someone killed or injured.
this means that those hydraulic locks are not a legal park brake. i had one on a wrecker i drove years ago and they do fail at the worst moment[/QUOTE]
Oh I'm aware it's not a legal park brake... however the bus currently doesn't have a park brake at all.. so something would be better than nothing. Lol.
I'm hoping to get the parking brake assembly though.
Old 06-09-2021, 04:31 PM   #22
Chassis: IH 3800
Parking brake assembly is on the way. Should be here next week.
Old 08-01-2021, 11:22 PM   #23
Hey, got any suggestions for a AT545 to A2000 swap? The drum driveline brake swapped over nicely but I need a bracket for the parking brake cable to mount on the rear of the transmission. I’m sure the A2000 had this in some cases so the bracket exists somewhere!
Diverdude0075 is offline   Reply With Quote
Old 08-02-2021, 04:48 AM   #24
Surprised it didn’t come with the trans from the donor vehicle. I made my own bracket. I looked for the gmc bracket used on the 7500/8500 trucks and couldn’t find one. I’ll have to look online again or maybe I can get a vin from one of the for sale uhaul chassis at my storage place. They all have hydraulic 1000 trans
Old 08-02-2021, 09:06 AM   #25
Thanks Chris. I think my donor bus had air brakes which would negate the need for the mechanical emergency brake. Luckily, I was able to get the drum brake on. I just haven’t been able to attach the cable. I may make a bracket, or pay a guy to help. It would be easier to find a bolt on solution though.
Old 01-16-2022, 04:54 PM   #26
Where were you able to find the parking brake assembly for the mt643? I am currently trying to figure out swapping out my at545 and havent been able to find the parking brake
Skacore3457 is offline   Reply With Quote
Old 01-16-2022, 08:14 PM   #27
Chassis: IH 3800
Literally a year of searching off and on. Finally found one at a random Allison rebuilder. I had called a half dozen shops that morning and finally found one.
They only had one and they'd had it for a few years. If you can't find anything, I'd consider a hydraulic option and wheel chocks as the transmission mounted units are JUST parking brakes and if applied during an emergency stop would likely just bust the tail housing.
Good luck!
Old 01-16-2022, 08:28 PM   #28
Do you have a part number or anything? Or is it just called parking brake assembly?
Old 01-16-2022, 08:29 PM   #29
You can stop a bus with that brake I know someone who did it as a test before they swapped their trans.. no it wasn’t me although I did do it from 20 mph as a test.. the one who did it from 60 made some good smoke but didn’t bust a U joint or driveshaft or tail shaft.. it’s definitely meant to be just a parking brake and wouldn’t last long as an emergency brake it did work ..
Wheel chocks are definitely not a good option. I seriously wouldn’t trust a line lock either.
Wheel chocks and a driveline brake are necessary well I always chock if I’m not on level ground or back against a curb in that bus
Old 01-16-2022, 08:36 PM   #30
I looked at your swap a little bit, an Allison 1000 or 2000 would be something to think about and the I could still use the parking brake. Do you know anything about swapping one into a 2000 gmc 7.4 454?
Old 01-16-2022, 08:55 PM   #31
Chassis: IH 3800
I don't have a part number for the assembly but each part has a stamped part number. I'll get the numbers off of it next time I'm out in the shop.
Old 01-16-2022, 09:05 PM   #32
I appreciate it, thank you!
Old 01-17-2022, 04:45 PM   #33
I found one! $680. Thinking I might go the Allison 1000/2000 route instead
Old 01-17-2022, 05:19 PM   #34
Chassis: IH 3800
Yeah they aren't cheap when you find them. With the 1000/2000, you'll need a controller too which are rather pricey also.
Good luck with what ever route you decide to take.
-NotSoGrand Garage-
https://www.youtube.com/channel/UCjw...WCpE8n6fLiplJA
Old 02-19-2022, 02:22 AM   #35
Any part number for this driveline mounted parking brake for at 545 ?
Polo Esperanza is offline   Reply With Quote
Old 02-19-2022, 09:51 AM   #36
Sorry, don’t know the part number for the at545 parking brake
