Old 07-06-2020, 08:01 PM   #1
Coachwork: International (Navistar)
Chassis: 37' FE Flatnose 3800FC
Engine: 7.6L DT466 with Allison MD 3060
Aluminum vs Steel Rivets
We are removing the escape hatches on top of the bus. What kind of rivets do we need and where do most people buy them? I bought the $70.00 rivet gun at Harbour Freight, but the only rivets they had were the Aluminum blind 1/4"x1/2". Wouldn't I need steel ones and again open or blind, what size, and where the heck can I find them? I bought the aluminum ones at HF, but now am unsure about them.
Maggie01 is offline   Reply With Quote
Old 07-06-2020, 08:06 PM   #2
I assume you're removing the hatches and riveting sheet steel over the openings? You want closed-end (which means they won't leak through the mandrel in the middle) stainless steel rivets, either 1/4":
https://www.rivetsonline.com/closed-...4ffph/pr84ffph
or 3/16":
https://www.rivetsonline.com/closed-...2ffph/pr62ffph
If you got the $70 HF riveter (the pneumatic kind, I assume) then you can do either 1/4" or 3/16". I'd go 3/16" for a patch like this; it's all you really need and they're $0.20 each instead of $0.50 each for the 1/4".
Rivetsonline is where I've gotten all the rivets for my bus so far.
Note: the "grip range" property gives the total thickness of material (all layers combined) that that particular rivet can handle. In the case of a patch like this, you add the thickness of the roof sheet (20 ga. or 3/80", most likely) to the thickness of your patch (say, 16 ga. or 1/16") to get the grip range you need to have covered (3/80 + 1/16 = 0.1). Technically this is outside the grip range of the 1/4" rivets I linked (.125-.25), but perfect for the 3/16" (.020-.125).
Edit: here's a useful thing on blind rivets: https://www.fastenermart.com/underst...nd-rivets.html To use a 3/16", you want to drill a hole between 0.192" and 0.196", for which a #11 drill bit is ideal. HOWEVER: the rivets you get may actually be pretty far off their nominal dimensions (the 0.25" rivets I got from them were actually 0.26" in diameter, so all the F bits I'd bought drilled holes that the rivets didn't even fit into), so wait until your rivets arrive, measure their diameters with a caliper, and add between 4/1000" and 8/1000" to get a drill bit size that will work for them.
Also: to make your patch watertight, run a bead of seam sealer (like Dynatron-550) around the edge of the underside of the patch before placing it on your roof, and also put a dab of sealer around the hole before you place the rivet and pull it (then wipe off the excess sealer with mineral spirits after you're done).
Also also: clecos will make your riveting life much easier. Here's a good starter kit: https://www.amazon.com/gp/product/B008PJWB2S/
Old 07-06-2020, 08:06 PM   #3
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
You can find rivets on ebay.
At one time you could even find space shuttle parts on ebay.
Old 07-06-2020, 09:43 PM   #4
Thank you!
