Originally Posted by cilantro
Uhh good question, can paint be applied directly onto clear coat? The paint suggested does say it can be applied direct to metal, not sure about clear coat.
Here’s the TDS
https://media.benjaminmoore.com/WebS..._31_TDS_US.pdf
It’s pretty light on detail. With the exception of bare metal requiring primer, previously painted surfaces are only i“as needed”, I would call their tech support and tell them what you want to do. Get specifics.
I would say you definitely want to sand through the clear with 320 grit on an orbital sander. Don’t remove the base coat.
Anyway, give them a call 1-866-708-9180,
