Old 12-02-2020, 07:01 PM   #61
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Unrelated to topic, but you can also clean and Rain-X headlights, glass and mirrors to prevent icing over in inclement weather.
Old 02-21-2021, 12:48 PM   #62
Engine: 5.9L 24V-L6 Cummins
Rated Cap: 37'
Originally Posted by Doktari View Post
I visited a friend I had not seen in a few years. He said he had gotten married and when his wife moved into his farmhouse she quickly began acting strange. Then she went literally insane. In the confusion he had the marriage annulled. She moved to stay with her Mom and recovered. He started doing some repairs on the farmhouse walls and found them lined inside with black mold! After lots or research on black mold he learned it can affect people’s behavior drastically.
How heartbreaking - did they get back together?
Yes, mold can be pretty devastating, not just effecting the respiratory system, but the endocrine (and thus hormonal), as well as neurological. I am a health care practitioner and treat it all the time.
https://www.immh.org/2017-video/brai...atric-symptoms
We're doing all we can to prevent mold growth. Our bus came mold free (though we viewed some horrendously moldy buses along the purchase journey). We still cleaned our bus 100 % about 100 times, and then followed another skoolie.net post advise and used chlorine dioxide bombs (oder bombs) to kill any mold we couldnt see left on any shreds of insulation we couldnt reach in the walls.
See below for what we've done to protect our bus in teh future, hope it helps others out! I acknowledge these measures were expensive, painfully so, However, chronic illness from mold growth is far more costly - and in more ways then one, as we learned from Dokarti.
1) sealing the behind-the-scenes-wood (furring strips, framing, floor grid, underside of wood floors and up side of ceiling wood) with a water resistant sealer and then painting it with a mold resistant paint (both products linked below). Both products are not toxic.
https://www.greenbuildingsupply.com/...dustrial-Paint
AFM Safecoat - Safecoat® Hard Seal
2) making sure the bus can breath - so that things can dry out. Rather then attempting to seal things up tight, which is impossible in a bus, we are making sure all furniture has circulation under it, mattress and cushions are resting on slats, and we will have little hidden fans running under each sofa and kitchen cabinet to improve air flow. Trying to make a bus air tight will result in a partly-air-tight-so-not-really-air-tight-and-therefor-not-breathable bus.
3) choosing breathable insulation. Toxic spray foam exacerbates the possibility of having a partly-air-tight-so-not-really-air-tight-and-therefor-not-breathable bus. So, we are using new zealand sheeps wool (not the rockwool, which is super toxic), which is naturally antimicrobial, mold resistant, and dries very well. Contrary to assumptions, sheep wool breaths very well and dries well when wet (sheeps wool insulation will not react to dampness the same way a sopping wet wool sweater would). We are also using cork as our floor insulation, very hard, and breathes and dries well.
https://shop.havelockwool.com/
https://www.ecosupplycenter.com/prod...AaAirIEALw_wcB
4) We also have two max air fans, which will improve circulation
5) A dessicant dehumidifier, uses very little energy, but is highly efficient. This dehumidifier (linked below) doesnt produce water, but rather burns up 85% of the humid air and then releases the remaining 15% of air as hot moise air, which can be hosed through the floor of the bus. No need for hoses, drains, or water collection.
https://www.northerntool.com/shop/to...B&gclsrc=aw.ds
6) Have breathable and dryable organic mattress and pillows, and an under-mattress pad. Also leaving space along side of mattress and head/foot of bed for mattress to breath.
Lots of brands of wool and organic cotton mattresses w organic latex, I pasted one below. Read about what makes a mattress breathable.
https://www.mattressinsider.com/matt...MaAjC6EALw_wcB
https://happsy.com/?gclid=Cj0KCQiAps...kaAmVAEALw_wcB
7) Avoiding propane, as that adds to condensation. Using electric stove (as much as we love gas, its just too risky) and a wood stove for heat. Diesel heater is our back up heat.
8. leave those holes in the floor behind that little lower wall, the ones you cant see. They allow for drainage. Just be sure to cover with a mesh screen so its not an access point for bugs.
Sevier is offline   Reply With Quote
Old 02-21-2021, 01:39 PM   #63
Rated Cap: 37'
Originally Posted by AlchemyCoeur View Post
Thank you for starting this thread. I have been living primarily off grid 6 months a year for 15 years... Mold is a huge issue with RVs and, as I am also extremely vulnerable to mold and still recovering from chemical burns to my lungs, one of the reasons I elected to to convert a bus. I am primarily concerned with choosing insulation because of this and still haven't figured out what type to use...anyway...excellent topic thank youl
Hello Alchemycoeur -
I totally feel your concern, is a big one of mine too, and I also, have health issues. Here is what we're doing to prevent mold growth. See my above post in response to Dokarti for lots of good mold prevention tips, I discussed insulation in #3.
Old 02-21-2021, 02:58 PM   #64
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
i tried rain x works for 10 minutes then same ole sh!t heated is probably the only way to go. it even dont work on windshields s far as icing but works great in heavy rain
mmoore6856 is offline   Reply With Quote
Old 04-24-2024, 03:08 PM   #65
Chassis: RE 3000
Engine: DT530
Update on your bus
I am extremely sensitive from mold and have been suffering from mold toxicity. I didn’t realize this until after purchasing a bus last year. Has it all worked for you guys? Did you end up having issues with mold?
closequarters is offline   Reply With Quote
