Old 03-30-2021, 10:51 AM   #1
witchywoman's Avatar
Year: 2006
Rated Cap: 30
Bathroom doors?
All right, I need suggestions. What did you do for a bathroom door? I don’t want to just use a curtain but I know standard size doors won’t fit.
What did you use? Pictures would be helpful too.
Thanks!
witchywoman is offline   Reply With Quote
Old 03-30-2021, 11:37 AM   #2
Chassis: Ford E450
Engine: V10 Gas
I bought a vinyl accordion-style door. Fits 24"-36". Still looking at it in the package, haven't installed it yet. Cheapest, fastest solution I could think of, and I'll install it in a pinch.
When I get to that point, I'll first look at saloon doors (Amazon).
Old 03-30-2021, 11:37 AM   #3
We used heavy duty drawer slides. The door is normally open so the slides are hidden.
Here its pictured open halfway.
Old 03-30-2021, 04:13 PM   #4
Flipmode's Avatar
Rated Cap: 48 passenger
That is a good idea! I really want to avoid the barn door trend but like the practicality of them vs pocket doors. *Saving this photo into my bus idea album
Flipmode is offline   Reply With Quote
Old 03-30-2021, 04:49 PM   #5
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
We don't currently have a bathroom door, the wall dimensions aren't right for it. Not an emergency or anything, but if I was going to do one, it would be the way you did it. Especially after today
kazetsukai is offline   Reply With Quote
Old 03-31-2021, 10:45 AM   #6
Year: 2008
Coachwork: IC
Chassis: IC CE300
Engine: Maxxforce DT
Thanks!
I re-purposed closet bi-fold doors (easy find at Goodwill), removed hinges in the middle, added hinges on the outside to open like narrow double doors, added magnets to keep shut while in use or parking, added door knobs as well with an elastic band to keep close during driving.
Seb1 is offline   Reply With Quote
Old 03-31-2021, 10:53 AM   #7
Coachwork: Blueburd
Chassis: International S1800
Engine: 9.0L International Diesel NA
drawer slides are a slick solution.... Could get a cleaner result if you mount the slides on the floor and the ceiling. basically a pocket door with out framing a pocket!
Box track hardware could work well too. might need a bottom mount fin on the floor to keep the door plumb. add some trim to hide the track and visible side gaps.
https://www.amazon.com/100PD-Commerc...8&sr=8-29&th=1
Rochey6957 is offline   Reply With Quote
Old 03-31-2021, 02:47 PM   #8
Year: 2006
Rated Cap: 30
All good ideas. I’ll have to do some further research.
