08-21-2022, 05:25 PM
Bathroom question
Since maximizing space is always the objective, I'm looking at it like Tetris.
Would it be possible to have a DIY composting toilet (basically a self-contained box with a lid) on slide out tracks to occupy the same space as a shower? Slide it out when you want to shower. Put it back when you're done.
I'm thinking an extra large, maybe sunken shower pan to have room for the extra hardware and wooden slats. And one of those hinged shower rods that expands as needed and folds back in when not in use.
Or am I dreaming? What do you all think?
Thanks in advance!
08-21-2022, 08:11 PM
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Welcome
Welcome to the Insane Asylum SFGrrrl. What kind of bus do you have?
08-21-2022, 08:37 PM
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
I don't see why you couldn't do this I've seen it done in van builds. You'd have to be carefull so that any vent ducting wouldn't get kinked when sliding the toilet back and forth.
The other option would be water proofing your toilet and having it stay in the shower area which would free up the space it would slide into for something else.
Ted
08-21-2022, 08:42 PM
No bus yet. I'm 58 and dreaming of retirement.
08-22-2022, 05:36 AM
Some people have done "wet" bathrooms where the toilet is basically just sitting in the shower stall and you sort of stand over it while showering; it seems like this would sort of suck. A slide-out toilet would avoid this but it might be difficult to do and keep the shower pan watertight.
I've played around with various ideas of having things (like a toilet, washing machine etc.) on platforms anchored to a pole in one of the outer corners of the shower stall. They would normally sit inside the stall but could be rotated out of the stall when you need to take a shower. The problem is that the pole and the platforms would need to be extremely strong since they'd only be supported on one corner.
08-22-2022, 09:20 PM
I can also make a waterproof cover. I may be needing a shower stool by then.
Thanks, folks!!
08-23-2022, 05:32 AM
Coachwork: Thomas Built Freightliner. Allison 2000 tranny
Chassis: Freightliner FS-65 (dognose)
Engine: Mercedes MBE 906 six cylinder diesel
Rated Cap: 35 feet long
The toilet I built calls for the user to tie up and dispose of the bag every time you poop in it. No warehousing poop for extended periods, so no exhaust fan needed. No slide out tracks either. Just pick up the toilet and put it in the hall when you want to have a shower. I’ve documented it's construction at theskoolielife.com Episode 17: Design and Build a diy Composting Toilet. (The final design of the urine diverted is awaiting a 3D printer arriving in November. )
08-23-2022, 10:17 AM
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
We considered something similar. Also considered a wet setup like musigenesis spoke of. In the end we decided that dealing with those compromises over the long haul would get really tiring (especially as we continue to age, where eventually they'd become limiting or even dangerous). With limited space, we decided to prioritize things that can't easily be done outside. So we're building a bathroom with separate toilet and shower. It will still be small (one window for each), but no hassle. What we gave up was seating for guests, but I don't really get the guest thing anyway. Outside is for guests (& 90% of our time too).
Go away. 'Baitin.
Our Build: Mr. Beefy
08-23-2022, 10:19 AM
Chassis: Ford E450
Engine: V10 Gas
Thanks in advance!
Tetris is the perfect term.
My Shuttle Bus bathroom is bout 40 wide x 30 deep and has a composting toilet that slides out.
Open/Extended:
Closed/Retracted:
The drawer slides are full extension 450 lbs capacity. I made the box ('cassette') from 3/4" veneer plywood (higher quality than sheathing). When not in use it retracts into a sealed enclosure under the kitchen counter.
I also have an exhaust fan, a standard computer cooling fan on a dimmer switch that extracts the air from the sealed enclosure into the vent stack.
You can see the enclosure fits pretty snugly under the kitchen sink. There's just enough room for a kitchen drawer over it, to the right of the sink.
Here's a more recent shot showing the cassette, instant water heater, and bathroom sink:
So yes, you can tetris it.
08-23-2022, 10:29 AM
Chassis: CE300
Rated Cap: 23
That's really nice, Rucker.
Go away. 'Baitin.
08-23-2022, 10:54 AM
Very cool, Rucker. Nice use of space.
08-23-2022, 01:51 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
hey rucker.
looking good.
dont forget the tailpiece under the sink?
if you are having a hard time finding the drain cup then go to your commercial kitchen/plumbing supply and ask for a drain basket for a bar sink.
08-23-2022, 10:29 PM
Rated Cap: 31,800 pounds
Thanks in advance!
The way I look at the sliding toilet question is that you have now created a toilet system that needs twice as much room and added complexity. What about building the toilet inside the shower (appropriately designed to not allow shower water into it) and use is as a "bench" or step. Ladies appreciate a place to step up on when shaving legs and such plus if there's ever someone using the bus with an injury having a place to sit is already there.
Of course if your shower is a tiny little 32x32 that won't work.
And if won't work with a flush toilet due to the plumbing.
Another space saving option with the shower is to not just use a rod and curtain but instead build a well supported door with closet/cabinet built in. When the shower isn't in use the door is closed and the closet/cabinet is occupying the space inside the shower. When the shower is in use, the door opens and a rod/curtain or roll out door keeps the water inside.
08-23-2022, 11:21 PM
@Rucker: Love it!! Just what I was thinking... all the water in one place.
08-23-2022, 11:25 PM
HamSkoolie, yeah, I said above that I may need a shower bench by the time I build my bus. I'll keep your door idea in mind. Thanks!
08-24-2022, 08:52 AM
Coachwork: Gillig
Chassis: Phantom 40'
Engine: DDECII 6V92T Allison MT647
Rated Cap: 37,400 lbs of potential
Thanks for the link David. You've shared some very good ideas in your blog, along with both thoughtful and entertaining commentary within your videos. Win- Win!
08-25-2022, 09:14 PM
What I don't get with a lot of designs - insisting on keeping the walkway where the original walkway between the seats was. It's almost like we're conditioned to see a bus as only coming with a center aisle. If the aisle were moved to the side, then there's quite a bit more room available for a bathroom, with storage inside. This also lends itself well to a kitchen design with the much larger wall to use, as well as a bedroom wall.
08-25-2022, 10:21 PM
Engine: 466ci
Rated Cap: 90
Washroom(s)
I absolutely agree. The hall is where my electric panel & shower valves are, similar to a home's hallway.
An 'L' shaped kitchen would work, too.
all-in-one washroom w/ side hall.
08-25-2022, 11:43 PM
Those of us who are tall and didn't do a roof raise prefer the center walkway as that's the highest point. I would bang my head with a side hall once we put in the floor and ceiling. It's not by much but it is an issue. Still, if a side all is only through the area next to a bathroom then the concern is minimized.
Our plan won't be final until we get the floor in and start taping things out. About the only two areas that are sure to remain as planned are the living are in the front and the bedroom in the back. And even then there are some design issues that will remain fluid until very near the end.
08-26-2022, 12:33 AM
No worries, I was just making an observation based on Rucker's very tight Tetris can right next to the factory walkway rubber. It's almost like the rubber center walkway get ingrained into the subconcious mind as a boundary that can't be crossed or something. Not that I'm knocking Rucker's design, of course. It looks very well crafted, and is a very efficient use of space, but looking at it with the eye of a 6 foot 4 man it also looks very difficult to use.
