12-30-2019, 06:40 PM
Chassis: TC2000-8 Window
Engine: Cumm ISB/Allison 2000
BB Questions 2002 TC Handi Bus
Being new to the bus territory, I have a couple of questions.
In some vehicles that I've had, the ECM would notify you of problems with beep codes. When I first turn on the key, I get two quick beeps, pause, another beep. Any significant meaning to this?
Photo 1 - Most of the buttons and displays are self explanatory, but what are these with W/L Master and W/L Start?
Photo 2 - Some time is shows a '7 c 1' code when starting the bus, but it eventually goes away. I've tried the three buttons on the right, but nothing changes on the display.
12-30-2019, 07:17 PM
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
I can't help on the second photo but the first one are for your flashers. I don't even know what the WL stands for but the yellow and red lights should be self explanatory. I had the same buttons on mine, and a fourth that made the stop arm and stop sign go out. Just finished pulling all those wires out today.
12-30-2019, 07:29 PM
Your second photo is a super crappy lcd clock. The sun cooked it and not it doesn't do anything useful.
I have the same clock.. I'll replace it with something more helpful at some point!
12-30-2019, 07:51 PM
And I thought for a minute how cool that was, a clock that reads the codes.
12-30-2019, 07:52 PM
Warning Lights
12-30-2019, 07:59 PM
Thanks JD! I had the school district disable flashers before picking up the bus. Looking at the snake of wires running fore and aft, I need to do some wire cleanup also.
Brokedown, I was hoping that you would tell me that it was an older version of a Scangauge D. Bummer, just a clock. I may be in the market to replace the clock with a Scangauge if it will fit. Thanks for the info!
12-30-2019, 08:01 PM
Originally Posted by o1marc
Warning Lights
W/L = Warning Lights
Makes sense! Thanks Marc!
12-30-2019, 08:24 PM
Warning Lights
Lol thanks! Now they're all gone anyway but it's good information.
12-30-2019, 09:10 PM
Those switches and wires can be repurposed,
