Old 11-16-2019, 12:12 PM   #21
I did a ten inch raise and I used something like 30" c channel. Measure and make it long as you can the more overlap the better.
He stated he wanted 5" overlap. I would use more, but that's what he wanted.
Is it better to have more than what is needed?
Old 11-16-2019, 01:04 PM   #22
Originally Posted by Skipoffools View Post
I did a 24” raise and I just took a chunk of the OE hat channel to a local fabrication shop and got him to custom make 48” hat channel to fit over the existing channel. This put the fabricated channel in the inside which kept the new channel from interfering with installing the exterior sheathing. Cost me $420.
I used farm jacks to raise and tek screws held it all in place for the 10 mile drive to the welder.
Gotta love it when a plan comes together!
Good job!
Old 11-16-2019, 02:10 PM   #23
How does the channel interfer with hanging metal?
Old 11-16-2019, 09:20 PM   #24
Chassis: TC1000 FE
Engine: 5.9
I just figured that would work! Thought I read a build thread where 5" was used. I can go a full 10" on each side I suppose
lebusmagique is offline   Reply With Quote
Old 11-16-2019, 10:05 PM   #25
I think you are adding strength exponentially by welding more than 20" per splice. Gonna be way stronger than before.
I didn't say 5 was not enough, and by more, I meant I would go 6". Any more is wasted material.
Old 11-17-2019, 05:28 AM   #26
More is more. I went ten inches overlap on each end. Its not like its going to hurt.
Wear A Mask- Stop the Spread!
Old 11-20-2019, 08:47 PM   #27
I bought my hat channels from a company called "Colorado custom coachworks" They sell them in 3 different lengths, 12", 16", and 20" long. They cost me $20 each. Same price for either size. They matched my channels exactly and just need to be welded in place.
Roscodude77 is offline   Reply With Quote
Old 11-20-2019, 10:04 PM   #28
Chassis: TC 1000
Engine: 5.9/AT
Rated Cap: 2 adults, 2 dogs
14" on a TC1000? Are you sure? With that short wheel base and small tires they're hard enough to keep on the road with a little side wind.
AZHippie is offline   Reply With Quote
Old 11-20-2019, 11:10 PM   #29
Two members of this forum got channel from them and were disappointed. CCC doesn't respond if you have problems. Took people MONTHS to get what they ordered.
