Old 11-12-2007, 05:07 PM   #1
swinada's Avatar
Bedframe steel
I use bedframe angle iron to screw the steelpanels to at the top of the window.
Most of them work fine, however now I have run into a problem that I can not cut the frames with the Sawsall or drill any holes. The first few frames went without a problem, this is a different bed i salvaged. Is there something different in bedframe steel that makes them very hard to drill????
I know that I once read something on VONSLATTS page about bedframes, I however cannot find it on his site right now.
Anybody any knowledge on this? A way to prepare the frames so they can be drilled?
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 11-12-2007, 05:48 PM   #2
the_experience03's Avatar
Re: Bedframe steel
The stuff is hard. I've found that annealing it with a torch makes life much easier. Combine that with good sharp bits, a slow drill speed, and lots of cooling fluid and it works ok. You sure can't beat the price.
Old 11-12-2007, 07:48 PM   #3
Year: 1985
Chassis: 745B
Engine: T326 9.0 L
Re: Bedframe steel
Hello. What gauge metal did you use to skin those windows? Any special technique or just measure, cut, and rivet? We are debating about removing some of the windows this early in the conversion or just tinting them and leaving them for now?
Thanks
Joseph
Joseph97297 is offline   Reply With Quote
Old 11-13-2007, 09:25 AM   #4
sportyrick's Avatar
Chassis: F33695
Re: Bedframe steel
A "good" bedframe is heat treated steel, tempered to be a springy so they can bend and return back to shape and still be light. This makes them hard to drill and they have enough carbon in them to present problems when welded (like a leaf spring). If you look at how they are put together they are rivetted, not welded. The best thing to use is regular low carbon steel you buy from a steel supply house. RR track is the same way, it has so much manganese in it you can't do much with it, too hard to drill, too much alloy to weld, makes great property corner markers. sportyrick
Old 11-13-2007, 09:27 AM   #5
Re: Bedframe steel
Thanks
Joseph
I used 20 gauge on mine, it worked very well. Plenty of strength and no vibrations.
Abbott is offline   Reply With Quote
Old 11-13-2007, 10:52 AM   #6
swinada's Avatar
Re: Bedframe steel
Thanks
Joseph
I used 18gauge steel, and used SelfTapping screws to fasten it to the bus. Cant tell you yet how it sounds driving down the road since I'm not done yet.
Start at the back of the bus work your way towards the front.
I used screws every 3"
used glazers putty between the frame and the steel panels. Comes in 30" rolls cost about $10 each.
I had the panels (4'x8') cut in half at the steel yard, dont know if that would work on your bus since window heights are different on buses. But having it cut at the steelyard is for sure easier then trying to cut it all your self. Measure twice, cut once.
Old 11-13-2007, 02:20 PM   #7
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Re: Bedframe steel
Originally Posted by sportyrick
. . .RR track is the same way, it has so much manganese in it you can't do much with it, too hard to drill, too much alloy to weld, makes great property corner markers. sportyrick
. . .and a short piece of it makes a great anvil, too!
Griff is offline   Reply With Quote
Sheet steel Zephod_beeblebrox2 Conversion General Discussions 19 12-31-2014 06:55 PM
fiberglass or steel? wmkbailey Conversion General Discussions 15 09-28-2013 07:21 PM
Project Steel Tent Gyre Skoolie Conversion Projects 26 06-22-2013 11:27 AM
I think it will work...Steel gauge rex_1_mn Conversion General Discussions 1 02-07-2013 10:08 AM
Painting galvanized steel??? dirtygoat Conversion General Discussions 1 08-15-2010 07:02 PM
