12-22-2020, 08:07 PM
Best price for rivets?
Roof raise and re-sheeting sides, forehead and rear.
12-25-2020, 06:48 AM
Engine: 3126b 210hp
Rated Cap: 48
01-06-2021, 07:43 PM
Originally Posted by Meathead
Looked all over that site and could not find 1/4" steel rivets to connect two 18 gauge to 1/16" framing. Can you post a link to what you used?
01-06-2021, 08:10 PM
They don't seem to have the 1/4" rivets for this. Jay-Cee has them: https://www.rivetsonline.com/closed-...4ffph/pr84ffph.
BTW, I bought a number of these for my bus and they are all around 0.26" diameter rather than their nominal 0.25", so you'll need a bigger drill bit than whatever you were thinking.
01-06-2021, 08:17 PM
Coachwork: MidBus
Chassis: Chevy Express 3500
Engine: 6.5L Turbo Diesel
Rated Cap: 19
Not sure if this is exactly what you were looking for: https://bylerrivet.com/products/blin...rivet-316-dia/
The URL says 3/16", but the description says 1/4". If you look under blind rivet s, they have many various ones available as "open-end", but a small selection under "closed-end". They even have copper/brass in open-end...
I'm not sure which type of rivets exactly I may want in the near future, but the site looks pretty reasonable for selection.
01-06-2021, 08:19 PM
Engine: 3208 na boat anchor
Just curious, but what does the solid side rivet head look like after the rivet is pulled.
01-06-2021, 08:30 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Thanks for the pointer to Jay-Cee. I like Byler, but I'll pay more if needed just to be able to see pricing and order...which I see Jay-Cee shows. It's a pain having to complete a quote request with Byler, then wait for pricing. I like instant! Need rivets now... <said in a gruff growly voice>
01-06-2021, 08:33 PM
Coachwork: MidBus
Rated Cap: 19
That may be a strong factor in my buying path too I don't like having to do the quote stuff either.
I also am curious on what the closed-end rivets look like when deployed.
01-06-2021, 09:05 PM
This is what the 1/4" blind closed-end SS rivets look like:
I put a little dab of Dynatron-550 into the hole in the middle of each one for aesthetics, otherwise the holes would be deeper.
01-06-2021, 09:08 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
From the front, I can't tell the difference between a closed or open end rivet.
01-06-2021, 10:45 PM
Coachwork: MidBus
Rated Cap: 19
Cool. Thanks for helping me visualize that.
01-06-2021, 11:14 PM
Year: 1973
Coachwork: Gillig
Chassis: 426D-13
Engine: 6VA71471 DD
Amazing to be ~10 posts into a thread on rivet prices without a single $ number...
For small lots (e.g. 100 / 250 / 500) of open ended blind rivets 1/8" diameter 0.188"-0.250" grip range recently I think I've paid ~$0.06 each for zinc plated and ~$0.07 for stainless. That's via Amazon so there is likely a cheaper way to buy them through a supplier and in larger quantities.
01-06-2021, 11:15 PM
That's how mine come out, and exactly what I do.
01-07-2021, 08:00 AM
Engine: 3126b 210hp
Rated Cap: 48
Call the guy.
Discuss needs.
Find out what other bus ppl. are using.
Get price.
Order.
Order more, get better price.
[emoji3522]
01-07-2021, 10:45 AM
Here is what I purchased from Byler rivet...they worked GREAT!
https://bylerrivet.com/products/blin...-rivet-14-dia/
spec sheet:
https://www.afshuck.net/us/uploads/B...20Brochure.pdf
I paid .34 cents each for 300 rivets.
Receipt attached:
