Originally Posted by vanman95
Thank you for the reply rossvtaylor! I’d have to say that the 3m marine is a strong adhesive! Have you used it as a sealant as well? How’s it handle vibrations and sun exposure?
Yes, it's a sealant that is approved for marine use below the waterline. It's just about the most permanent stuff I've ever seen in a tube and it's impervious to vibrations. I cannot answer the sun exposure, because I use it between surfaces (either lap panels on the roof raise siding...or between the solar brackets and the roof skin). In these places, it doesn't actually see the sun.
5200 is something you should only use for something you consider permanent. If you might want to remove something, someday, you can use the 4200. It's still a bear to remove, but you won't totally hate life while doing so.
