04-07-2023, 08:16 PM
Chassis: 30ft International FE | Gear Ratio 4.63
Engine: INTL DT466 HT 215HP/2400 GOV
Rated Cap: GVWR: 34220
Best Seam Sealer?
Hey Everyone. I am starting the process of re-sealing my entire roof/all the seams. I am trying to decide between dynatron 550 (seems to be popular) and 3M Urethane Seam Sealer, 08368.
Does anyone have experience with both of these? Which did you find to be the best?
https://www.amazon.com/3M-08367-Blac...007NIQONO?th=1
https://www.amazon.com/550-Permanent...005RNFBMC?th=1
04-07-2023, 11:13 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
I absolutely prefer the 3M, for its "workability" and the ability to smooth it. I find that the Dynatron is very hard to smooth and it wants to ball up, pull, and generally fight me. Maybe I'm doing it wrong, but I've tried about 5 different tubes of it (primarily because our local Auto Zone carries it) and just don't care for it.
Recently...and finally!...I've been able to do a bit of work on Stevie, our Crown, and I have 4 tubes of that 3M on the shelf for sealing seams on that bus (after I wire brush and remove some loose paint at the seams).
04-07-2023, 11:42 PM
I wonder if you've gotten somewhat older, dried-out tubes of the stuff. I always use it with a spray bottle of mineral spirits. Misting the dynatron down with mineral spirits keeps it supple and easy to smooth out and prevents it from skinning over until I'm done working with it. I've never used the 3M so maybe that just works better right from the tube, I dunno.
Chassis: TC2000 28ft
Do you wet a finger with anything to tool it?
04-07-2023, 11:52 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Now you tell me... I'm sure it was operator error on my part. Our Auto Zone has a normal stocking quantity of exactly one tube, so I'd buy one...wait a few weeks...buy another...and so on. I think they were fresh.
Uh...no, I didn't. Which was most likely my issue. It skinned over very fast and I should have tried (but didn't know about) musigenesis' mineral spirits suggestion.
04-08-2023, 11:59 AM
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
I’ve used Dynatron on a lot of my bus but I do find it works much better when it’s warm outside and the tube itself is warm. It is very sticky and may not be the best tool for every job. I bought a different kind for my roof seams and it was much easier because it wasn’t as sticky but I can’t remember what it was called…I’ll update later when I remember or get home.
04-08-2023, 12:33 PM
Year: 2008
Chassis: Blue Bird Vision
Engine: 6.7 Cummins
Sikaflex 221
We've been very happy with Sikaflex 221. Flexible and tough. Definitely need mineral spirits for clean up and tooling.
04-08-2023, 12:45 PM
Year: 2006
Chassis: MVP-EF
I remember! I used Sem automotive seam sealer on the roof. A little pricey but less sticky than dynatron.
04-08-2023, 12:46 PM
Year: 2006
Chassis: MVP-EF
Mineral spirits in a bottle will help with a lot of the process for any of these seam dealers. I think I’ve used paint thinner too, makes the sealer a little more elastic if it sets up too fast and will pick it up if you accidentally get it somewhere you don’t want it.
04-08-2023, 01:02 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Originally Posted by dbsoundman
I remember!
Yay, for coffee!
04-09-2023, 05:10 PM
ive been using good old dynatron 550 for decades and it has held up well for me over the years.. it is definitely sensitive to cool.. I almost always work with it when its good and warm for both the tube and the surfaces.. a urethane might be less sensitive ive really never tried anything else as 550 is in stock about anywhere you go
04-09-2023, 06:49 PM
Thanks everyone. I actually first tried going with the 3m stuff I posted but apparently it is packaged in a flexible tubing and I don’t have an application tool for it. So i went to my local AutoZone and got some dynatron.
That stuff does not spread easy without water/mineral spirits. I applied it pretty heaving with hope that it will be able to partially sand when I sand the roof for painting.
04-09-2023, 08:54 PM
I don't think you're going to be able to sand Dynatron-550. I wouldn't worry about it since your roof seams are not really all that visible from the ground.
04-10-2023, 06:16 PM
Year: 2011
Coachwork: Thomas C2
Engine: Cummins 6.7L
Rated Cap: 48 seat 30ft
Originally Posted by [LEFT
nconn[/LEFT];490511]That stuff does not spread easy without water/mineral spirits. I applied it pretty heaving with hope that it will be able to partially sand when I sand the roof for painting.
It will pull out if you try to sand it, same with caulks and silicone. Save yourself a few hours! And Rusty has a point, no one will see it. If it does need to be neatened up you could always paint the roof with a thicker elastomeric paint which is basically rubber in paint form. Or add more seam sealer to make it more uniform way better than sanding down too far and having to reseal the metal.
Also, not sure if you used painters blue masking tape but that will give you very straight seam lines like a pro, with less cleanup (if you are careful removing the tape).
04-19-2023, 06:43 PM
Chassis: Safe-T-Liner
Engine: Cummins 24V
IMO 3M is the best
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Silka is a great alternative, or any urethane window/door sealer.
04-19-2023, 06:50 PM
Coachwork: Midbus
Chassis: Chevy Express G3500
Engine: 6.0 V8
Rated Cap: 12+2WC
I have not used Dynatron but I used 3M automotive urethane to reseal my windows and I’ve been very happy with the performance. The only complaint I had was it did not stay white for long. It turned a dingy sand color within the first week so don’t buy the white stuff expecting it to stay white.
04-20-2023, 07:26 AM
Engine: 8.3 Cummins mechanical injection
Has anyone used 3m 5200? I used it for sealing my window patch panels and a box I made in the back to expand the engine compartment for easier working under the bed where the back seat bench was. I also recommend the tape lines method, we put windows in airplanes that way, tape 1/4” away from the edge on the window and right on the edge of the metal and then smooth the sealant down with a little metal spatula, then peel the tape off while it’s wet and it’s perfect fillet every time.
04-20-2023, 11:05 PM
I don’t see many people mentioning sikaflex 221 or the UV equivalent here. Any reason?
04-24-2023, 12:54 PM
Year: 2006
Chassis: MVP-EF
Too many alternatives and people tend to get overwhelmed (like me) and pick the most common options like Dynatron even though it's not necessarily the best for all applications (in my case I find its really sticky, which makes it hard to work with sometimes).
04-24-2023, 06:24 PM
Year: 2011
Also would depend on the area etc. Sikaflex is easy to find in Aus and NZ but less so here in Ontario, I’ve been recommended it by boaties since it’s used to bung holes in yachts and I’ve done a shipping container roof patch with it.
