Old 05-15-2020, 10:19 AM   #1
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Best way to temporarily waterproof holes in roof?
Got roof painting to do, and hole cutting for items we don't yet own.
Figure if I cut the holes now, I'll use less paint. Plus, I get to cut holes in metal now & now later
We've got monsoon season on the horizon. Some holes might not be filled by then.
How would you temporarily seal up holes in the roof from the outside in a manner that will come off clean & easy, but not rip off during a summer storm? Anything from 3/4" holes up to standard 14 x 14 openings.
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 05-15-2020, 10:25 AM   #2
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
Figure if I cut the holes now, I'll use less paint. Plus, I get to cut holes in metal now & now later [emoji3]
Really thin plexiglass and butyl tape maybe
JDSquared is offline   Reply With Quote
Old 05-15-2020, 10:45 AM   #3
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
water proof holes
dont make a hole and it cant leak. easiest way to water proof a hole is not to make a hole.
anything you put on the roof is a possible victim to high winds... so an alternative is indoors or under cover. can you move this under any sort of awning ?
I have seen a tarp that was anchored with 55 gallon drums filled with water.... one of those 55 gallon drums ended up 100 ft away through the front windshield of somebody else's truck. That was not a fun day with the insurance company..... summer storm in Kansas.
That is why I say anything you put on the roof or over the roof is possible victim of the wind. I never ever would of thought that drum filled with water would ever have been picked up........
william
Old 05-15-2020, 11:05 AM   #4
Chassis: CE300
Rated Cap: 23
william
All really good points. I may reconsider my plans.
That being said, the interior is gutted, the floor is sealed, and before I start cutting the interior shell will all be primed. So if it does get wet inside from a blown-off cover, it's not really that big a deal.
Go away. 'Baitin.
Old 05-15-2020, 11:37 AM   #5
Gator tape and plastic sheet has worked for me. For a 14x14 hole I'd put a slightly-bent strip of sheet metal over the hole first to keep the plastic propped up a bit and prevent water from accumulating.
Old 05-15-2020, 11:41 AM   #6
Chassis: CE300
Rated Cap: 23
What's gator tape, Musigenesis?
Only thing I find w/ a search is traction tape under that name.
Go away. 'Baitin.
Old 05-15-2020, 11:45 AM   #7
I was thinking the same thing about making sure I had all the holes made before paint so in case I messed up it would be easier to fix. I ended up cutting after paint and it wasn’t a big deal.
Old 05-15-2020, 11:51 AM   #8
Er, I meant Gorilla Tape. Sorry, I went to UF - we think we invented everything.
Old 05-15-2020, 06:39 PM   #9
Chassis: CE300
Rated Cap: 23
Ok, got it. Thanks!
Go away. 'Baitin.
Old 05-15-2020, 10:51 PM   #10
I dated two girls from UF. They were a blast but you ain't kidding about that.
Old 05-15-2020, 11:03 PM   #11
Did they use "Gator" tape on you?
Old 05-15-2020, 11:47 PM   #12
The only things we actually deserve credit for are Gatorade and the forward pass, invented by Steve Spurrier in the 1990s.
Old 05-23-2020, 04:20 PM   #13
BillK's Avatar
Chassis: GMC G3500
Engine: 5.7L
Rated Cap: 22
I’m dyin’ ova here!!! LMAO!! GREAT response!! I grew up in Orlando and my whole family are Gator fans. ��
BillK is offline   Reply With Quote
Old 05-27-2020, 03:54 AM   #14
Rock-N-Ruth's Avatar
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
The don't make holes method of leak prevention is great. If you want to save on paint on the big spots you will cut in the future, mask them off before you paint. Be like a carpenter with CRS, measure 20 times and cut once, after dinner.
Rock-N-Ruth is offline   Reply With Quote
