04-05-2019, 10:22 PM
#21
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Is the starter clicking, or a relay? Either then it is bad, or you gotta hellava short.
It's so fun diagnosing by guess without honds-on, a voltmeter in action, or more info than "help it won't start"...
04-05-2019, 10:24 PM
#22
Rated Cap: 26 foot
or maybe the motor-to-battery-ground wire has corrosion on the terminal(s)
04-05-2019, 10:29 PM
#23
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
I've got a volt meter. It's a brand new starter. It worked before. I'm baffled
04-05-2019, 10:36 PM
#24
Coachwork: myself
Chassis: amtran
It's the starter clicking
04-05-2019, 10:39 PM
#25
Rated Cap: 26 foot
Is it getting a full 12-volt "signal" to the starter solenoid to engage the starter gear?
Sometimes you need to test this with a test-light, not a digital gauge. The light will show that it is receiving amps, not merely volts.
Often a relay between the key-switch and the starter will go bad, still click, still pass voltage, but not amperage.
Other times I have found the ECM is sending voltage, but not amperage, to activate a relay, i.e. the ECM is going bad (that was a AC system, not a starting system, but same circuit design.
Is the starter "clicking" when you turn the key? Is another relay clicking?
04-05-2019, 10:41 PM
#26
Coachwork: myself
Chassis: amtran
The starter clicking
04-05-2019, 10:42 PM
#27
Rated Cap: 26 foot
If the starter is new, not from Pep-Boys, and tests out on a bench test or another vehicle, and the battery is new and starts other motors of the same type, then I would start thinking about the motor ground wire.
Or a bad "new" starter.
#28
Coachwork: myself
Chassis: amtran
I'm thinking it has something to do with the ecm. I'm going to try again tomorrow
04-05-2019, 10:44 PM
#29
Coachwork: myself
Chassis: amtran
That'salways a possibility. I got it from rush truck parts. It worked for a week.
04-05-2019, 10:56 PM
#30
Rated Cap: 26 foot
The first vehicle repair job I ever did was an alternator from Pep-Boys. 2 bolts, and two wires. It did not work. I was so frustrated, and towed my truck into a shop. The guy came out with my "true-blue" alternator in hand and said in an east-Jersey/Bronx kinda accent "lemme tellya one thing- never go to Pep-Boys." Lately I shun Autozone. Too many of my customer's parts were just plain wrong, or cheap-o creap-o.
Good luck. Wish I was "there" for you.
04-05-2019, 10:57 PM
#31
Coachwork: myself
Chassis: amtran
Thanks I'm gonna try again fresh in the morning
04-06-2019, 09:04 AM
#32
what does the bluefire say? it should read the current computer data assuming the computer is powering up correctly.. any DTC codes?
also, measure the voltage at the batteries themsekves when turning the key to "start".. that 8.1 if at the battery and the starter isnt spinning the engine is way too low to fire the starter or the injectors..
the other possibility thgiough very unlikely is that the starter motor is engaging but unable to turn the engine.. (ie spun a bearing and seized it).. you'd likely get smoke from the starter wires pretty quickly if thats the case.
the computer has 2 feed circuits.. 1 is BAT+ and the other is ignition+, if both are powered up, your bluefire will be able to talk to the diagnostic port at Key-On engine off .. it should display current coolant and oil temps as well as battery voltage at the ECM..
if the bluefire doesnt talk at key on, then we know the issue is in one of the power circuits to the ECM..
be sure a wire didnt get against the exhaust manifold and melt, that the 2 connectors on the computer are secured.. (dont overtighten)..
those 2 plastic turn wheels on the computer love to strip out.. theres a center screw in each one of those.. you can take the plastic wheel off and use a 10MM socket to snug the ECM connectors.. snug not torque down. over-tighten and ther connectors crack.
the wires on the starter junctrion terminal coming loose from engine vibrations is also a possibility..
im niot ready to shoot the starter dead as the underlying thing here is that the bus was running dopwn the road and shut down.. so whatever this is happened without the starter being involved..
04-06-2019, 09:22 AM
#33
Rated Cap: 26 foot
I did not even want to mention "seized"
04-06-2019, 09:31 AM
#34
Coachwork: myself
Chassis: amtran
It is still connects. The read out says code followed by an L and the word description. it says to tap fault formore info but nothing happens.
04-06-2019, 09:36 AM
#35
Coachwork: myself
Chassis: amtran
Now it's not connecting.
04-06-2019, 09:37 AM
#36
Rated Cap: 26 foot
Why would the starter click (make sure you put your hand on it (or mechanic's stethescope)) if the ECM is bad? If the ECM was bad, the starter would never get a signal to make it click.
Every time I had a starter that "clicked," it was bad; every time in 30 years.
04-06-2019, 09:39 AM
#37
Rated Cap: 26 foot
Voltage? (at battery and dash gauge)
#38
Coachwork: myself
Chassis: amtran
That makes sense. Im confused about the voltage drop with the key in the on position.
04-06-2019, 09:40 AM
#39
Coachwork: myself
Chassis: amtran
The blue fire isn't connecting
04-06-2019, 09:44 AM
#40
Rated Cap: 26 foot
There's your problem! Short somewhere. I missed that part, I thought the voltage only dropped when starting...
Assuming your battery is good; oh, and there is no diesel heater coming on.
