Old 05-08-2007, 01:08 AM   #1
KaptnKAOS's Avatar
brake light ?
Hey Everyone...
I wanted to let ya know that I got my tail lights and turn signals all working ... yes !!!
Now, I am trying to figure out the brake lights.
I was looking for the switch and wasn't able to locate anything that looked like the switch on my '68 F-250. There are two wires going to a a metal rectangle. The plunger rod for the master cylinder connects to the same piece, but I didn't see anything that resembled a switch.
I was wondering if anyone could shed some light on this for me...
Thank you,
KaptnKAOS
Washington...
The land where rust is like the family pet...
Ya learn to live with it and clean up after its mess... KaptnKAOS
Olde Skool '68 Ford Bluebird bus "Shorty"
https://rides.webshots.com/album/559029491BwEQCZ
KaptnKAOS is offline   Reply With Quote
Old 05-13-2007, 08:33 AM   #2
I believe you may have found the switch jeep and the older fords used a switch that mounted on the pivot at the brake pedal. If not I would look in the area around the master cylinder may have a pressure type switch screwed into the master or t-ed into a line.
odee is offline   Reply With Quote
Old 05-13-2007, 07:40 PM   #3
phillbus914's Avatar
My 91 Bluebird TC2000 had a pressure type switch that was mounted inline with one of the brake lines. Pressure from the brake fluid activated the switch and turned the brake lights on.
I had an issue with it last summer and it shorted out causing the brake lights to stay on all the time, which caused the back-up brake booster to run all the time, which caused the switch to over heat and leak.
I had to replace it with an updated, plunger type switch which is mounted near the brake pedal and activates when you step on the pedal. You can read about that adventure here...
http://www.skoolie.net/forum/viewtopic. ... highlight=
good luck!
My Old Bus :(
phillbus914 is offline   Reply With Quote
brake light switch please help littleangel47 Mechanical and Drivetrains 3 08-07-2019 11:24 PM
brake light switch please help littleangel47 Mechanical and Drivetrains 5 03-19-2012 01:19 PM
Brake Pressure light.. colliervilledave Conversion General Discussions 6 07-23-2008 10:12 PM
Ghost In The Brake Light Machine dancarrigan Conversion General Discussions 2 05-01-2008 02:48 PM
I'm having a brake light problem... DGC3 Everything Else | General Skoolie Discussions 3 04-18-2007 07:37 AM
