Old 06-30-2021, 02:13 PM   #1
Bus Floor Gauge
Hi,
What is the standard floor gauge on buses.
I have a few sections to replace
2006 IC CE3000
Ben3361 is offline   Reply With Quote
Old 06-30-2021, 02:54 PM   #2
ICs use 16 ga. for the floor.
Old 06-30-2021, 03:51 PM   #3
ewo1's Avatar
16 gauge is best.
If you use 18 ga it will flex and pop when you step on it. 16ga is thicker and won't flex.
18 ga, if that's all you got, then use it but if your doing large sections, 16 is better.
Old 06-30-2021, 04:20 PM   #4
Originally Posted by ewo1 View Post
16 gauge is best.
I think anything from 14 to 20 will work fine if you're building a subfloor with 3/4" plywood over top of it anyway.
Old 06-30-2021, 10:23 PM   #5
Thanks all.
I will go with 16 gauge
