Old 09-18-2017, 05:55 PM   #1
cschuck3's Avatar
Engine: DT360 Diesel
BUS Lights
Ok So I am planning to convert a few of the bus light over, and wanted to know which it effects DOT? There are 4 big round light which I want to convert to BRIGHT Day Maker style LED lights and hoping it will be legal??
cschuck3 is offline   Reply With Quote
Old 09-18-2017, 06:03 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Not driving on public roads with them on in the US, right? As headlights or Off-Road lights? The high ones will get you berries and cherries.
Height of headlamps must be at least 24” but no higher than 54”.
Old 09-18-2017, 06:05 PM   #3
cschuck3's Avatar
Yea, Like can I use the Harley Day maker lights and use for off road?? Or like does I need to keep those lights red and working for DOT?? or can I change them out for something else fro off road or bad weather????
Old 09-18-2017, 06:14 PM   #4
Traveling
Rated Cap: '00
You need the turn signals up front, and you need the running lights up front. Up top, you need the clearance markers. The other stuff is optional, but not if it's blinding. You see big rig trucks that have all those extra cool lights.
Check out these lights- few different color LEDs in same package
Raney's
If you get hassled, flip the switch and legal. I just finished(almost) painting and am deep into LED marker research myself...
