Old 10-30-2021, 03:43 PM   #1
Year: 2008
Engine: Mercedes MBE900
Rated Cap: 40 passenger
Bus seat rail removal???
Hi all, my first post here! I’m a new owner of a 2008 Thomas mid size (28 feet). I am planning on a roof raise and in the middle of demolition work. I have seen repeated references to the structural reliance of the seat rails. I don’t seem to see the necessity in my bus. I will post pictures if I am able, but it looks like the steel floor bends up along the edges and the hat channel is welded to it. The side panels also are the same thickness and one piece from bottom of window to floor. I am no engineer, so I feel unqualified to make an absolute determination, so I would love some opinions on this. Thanks, Mark
3A1ABD3E-F63B-422A-BE5A-6C2193705DED.jpg   232E34AD-A8FA-48E8-BFC8-0E108C2D6F28.jpg
ZoomerVanGough is offline   Reply With Quote
Old 10-30-2021, 06:51 PM   #2
The hat channels are not welded to the floor, they are attached with bolt on brackets. The chair rail ties it all together and is structural.
Old 10-30-2021, 07:23 PM   #3
Year: 2008
So in the case of being a necessary piece, if I remove for access to the wall and wall cavity below the floor, what about welding it back once the wall panel is removed?
Old 10-30-2021, 08:51 PM   #4
Weld it at every point there was a screw or rivet.
