Originally Posted by Hutchy
this is probably a stupid question but would you say definitely change the oil before driving it home 600 miles?
I've never changed the oil on any bus I've bought right away I just bring em home carefully and make sure the levels are good . I check to make sure there's a proper level, make sure to keep some extra oil on hand (they use a bit usually). Once I get home I do a full change with fuel and oil filters and I even do the trans oil too.
I'd probably bring a grease gun and hit the u-joints since its sat. That's easy enough.
