Old 08-23-2021, 12:38 PM   #1
Can I use 2 different sizes of heater hose?
I'm rerouting my coolant line under my bus and currently the system is using 1" but I would like to mend in 3/4 for the two 30ft runs under the bus.
Would this cause pressure issues or cause air bubbles?
adioteque is offline   Reply With Quote
Old 08-23-2021, 03:49 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
do you have a pump to move the coolant?
either way i dont think it would cause to much issue other that your heater wont get as much flow as it used to.
example 1" pipe carries 12 gpm and 3/4" pipe carries 9 gpm.
notice i said example because there are variables that factor in for specific fluid,pressure and bends ,turns, heater connections, heater core itself but at a minimum in a perfect world your heater will not be as efficient as it was.
Old 08-23-2021, 04:10 PM   #3
The hope is that a lessened flow would not be an issue because less parts are being serviced but then again those heaters were dispelling heat, even off. so the coolant would theoretically be hotter.
