Cargo Carrier tow hitch installation
Here are some photos of the hitch, riser. My bus had two large hooks attached at the rear for loading or towing purposes. There are four large metal plates bridging the two frames sides for strength, I mean heavy plates! Right angle plates were installed to accomodate the two hooks. I could not use the holes, but the right angle plates were perfect for my tow bar attachment. I had to drill about eight holes to make this hitch work. !/4" steel everywhere. The hitch is rated 5000 lb towing 500 lb tongue weight.
