11-22-2021, 02:48 PM
Check Out This beast
Lots of potential for the right builder. It's in the UK. Weird seeing the double wheels up front. If it were here, it would be mine.
https://www.ebay.co.uk/itm/185167593...81-19255-0%2F1
11-22-2021, 06:32 PM
Engine: Cummins 8.3
And the roof raise is half done!
11-22-2021, 06:39 PM
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
Also looks to be right hand drive. I don't think I totally get why dual steer axles but I've also seen this I think in some South American buses. In US the only time I've seen this is very heavy vehicles like semi tow trucks and driveable cranes. For a bus of average size it just seems like it's unnecessarily complex.
11-22-2021, 06:41 PM
Engine: Cummins 8.3
I gives you 1 more braking axle. I can see that coming in handy.
11-22-2021, 06:53 PM
Chassis: 31 ft. HDX
Engine: CAT C7 250 hp
Rated Cap: 36,300 GVW
I think that bus is an old race car hauler. The junk on the roof is for tires and spare parts.
Definitely a big project.
11-22-2021, 07:52 PM
Coachwork: Crown, integral
Rated Cap: 37,400 lbs GVWR
I've ridden many a mile in old Bedford VALs, usually with Duple bodies, and always with the venerable Leyland O.400 engine making more noise than progress. The VAL was a product of the 1960s, when anything mini was trandy: Mini cars, mini skirts, and buses with mini-ish wheels to achieve a lower floor height without wheel humps inside. Bear in mind that VALs were front-engined, so their front suspension could be set to ride better even with the weight of a heavy engine next to the driver. Of all the buses I've been on, VALs are not my favorites (actually no Bedfords are); give me a Leyland Leopard or Bristol RE any day!
11-23-2021, 10:17 AM
Jeez, maybe the title gave it away?
Top Box is observation deck, and can be removed. No storage.
"1966 Bedford VAL classic race transporter coach "
Bus sold for L$2950
11-23-2021, 03:34 PM
Chassis: TC2000, 40' MPV
Rated Cap: U/K
How much for a front end alignment?
11-24-2021, 12:47 PM
Engine: Cummins 8.3
Same as a 3 axle truck alignment?
11-27-2021, 04:14 PM
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
are the front axles also drive axles? the engine seems to be far enough forward to have a trans between it and the front axle?
11-27-2021, 07:58 PM
Year: 2008
Coachwork: IH
Chassis: IC SB CE-300 39ft
Engine: DT466 w/Allison 2500
Rated Cap: 29500
$500. $20 for the very big antique hammer and $480 to know exactly where to apply the blow.
11-30-2021, 02:49 PM
Nah, of course not! It's merely a conventional truck-configuration front-engine bus, just with an extra front axle. There's no room for a transmission and a driveshaft ahead of the frontmost axle, unless you ran the driveshaft over the axle(s) to a transmission behind the axles, then forward to the axle(s) just like a Bristol RE does. Or maybe use a dropbox like some Eagle buses or MCI's MC5 bus, but that's just another source of mechanical complexity.
There are four-axle buses in Peru, a modern version of the old Sultana four-axle buses in Mexico, but they're the only other buses I know of with two front axles.
11-30-2021, 04:38 PM
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Eight Wheel Motor Vehicle Co.
An early example of a four-axle bus is from Eight Wheel Motor Vehicle Co., (1918-1931) who manufactured such a bus (and trucks).
The Fageol (pronounced fadjl) brothers also owned Fadgl Flexible System Inc. (1915-1917)
Which is why Flxible (1919-1974) spell their buses' name oddly.
The patent drawing 1921,
The Pacific (1922)
Fageol Twin Coach (1927)
12-01-2021, 12:04 AM
Rated Cap: me + 1
transaxles? or portal axles? It just seems that getting a conventional transmission and driveshafts past those front axles would also be "just another source of mechanical complexity."
12-01-2021, 12:21 AM
Rated Cap: me + 1
The Pacific (1922)
Wow, twin engines and some kind of portal axles? Did these guys have some kind of military connection?
12-01-2021, 05:36 AM
Engine: 466ci
Rated Cap: 90
Caley & Nash
Eight Wheel MVC didn't have any direct military contracts, that I know. The Fageols (Twin Coach) did manufacturer wing & fuselage assemblies for Boeing, Grumann, North American & Republic from their Cheektowaga plant.
Early bus builders transitioned from stage coaches at a time when wagon trails were more abundant than roads. The Lincoln highway wasn't yet completed and city streets did not connect to neighboring towns.
Caley & Nash (1880-1947) had a bus with a similar four axle design. This one is from 1922.
